302-08MP Voice Vlan issue
philip.lock
I have a 302-08Mp attached to my network, it is plugged directly into a C3560G, however when i plug a phone into this switch i get a 'configuring ip' message up on the phone. The voice vlan is set identical to the 3560 but in the logs i get an error message stating
%CDP-W-VOICE_VLAN_MISMATCH: voice VLAN mismatch detected on interface gi1.
Can anyone help me solve this issue?
Thanks in advance
6 Replies 6
Tom Watts
Hi Phillip, can you post the config of the port connection that go to each other from each switch? What is the management, data and voice vlan?
What software are you running on the SX300?
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Tom,
Sorry for teh delay i needed to get someone at the remote location i could trust to reboot the unit. The voice vlan is 20 and the rest run on vlan 1
the 302  is set as
interface gigabitethernet1
macro description "switch | no_switch | switch | no_switch | switch | no_switch
| switch | no_switch | switch | no_switch | switch | no_switch"
exit
macro auto disabled
macro auto processing type host enabled
macro auto built-in parameters ip_phone_desktop $max_hosts 10 $native_vlan 1
and runs sw version 1.1.2.0
the 3560 is set
interface GigabitEthernet0/3
description Link to SW3
power inline never
switchport mode trunk
switchport voice vlan 20
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape  10  0  0  0
queue-set 2
mls qos trust cos
auto qos voip trust interface GigabitEthernet0/3
power inline never
queue-set 2
mls qos trust cos
auto qos voip trust
The voice vlan maco is disabled on the SF300.
You'd have to manually configure the port with that current config
config t
int gi01
switchport trunk native vlan 1
switchport trunk allowed vlan add 20
The phone port configuration would have to match as well
-Tom
Thanks Tom, do the phone ports also need to be set for trunk mode?
yes
-Tom
Thanks Tom, at least now i get the ip address its just a shame the phone now comes up with a 'error pass limit' message when you attempt to use it
