07-05-2017 11:27 AM
I have stack switches of eight WS-C3750E-48PD they all share same image , stack switch members reboot everyday at 11:30 AM
Switch Ports Model SW Version SW Image
1 54 WS-C3750E-48PD 15.0(2)SE10a C3750E-IPBASEK9-M
2 54 WS-C3750E-48PD 15.0(2)SE10a C3750E-IPBASEK9-M
3 54 WS-C3750E-48PD 15.0(2)SE10a C3750E-IPBASEK9-M
4 54 WS-C3750E-48PD 15.0(2)SE10a C3750E-IPBASEK9-M
5 54 WS-C3750E-48PD 15.0(2)SE10a C3750E-IPBASEK9-M
* 6 54 WS-C3750E-48PD 15.0(2)SE10a C3750E-IPBASEK9-M
7 54 WS-C3750E-48PD 15.0(2)SE10a C3750E-IPBASEK9-M
8 54 WS-C3750E-48PD 15.0(2)SE10a C3750E-IPBASEK9-M
Anyone have any idea how to fix the issue without RMA the whole switch ?
or anyone have idea how to find which one of the switches has the problem without changing the switches individually ?
Mudher Alattar
07-05-2017 02:34 PM
Post the complete output to the command "sh version".
07-06-2017 05:36 AM
Here we go :
Cisco IOS Software, C3750E Software (C3750E-IPBASEK9-M), Version 15.0(2)SE10a, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Thu 03-Nov-16 13:43 by prod_rel_team
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750E-HBOOT-M) Version 12.2(35r)SE, RELEASE SOFTWARE (fc1)
Rogerdale-3750-40-49 uptime is 11 hours, 8 minutes
System restarted at 20:26:55 CDT Wed Jul 5 2017
System image file is "flash:/c3750e-ipbasek9-mz.150-2.SE10a.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3750E-48PD (PowerPC405) processor (revision B0) with 262144K bytes of memory.
Processor board ID CAT1125RG6A
Last reset from power-on
2 Virtual Ethernet interfaces
1 FastEthernet interface
416 Gigabit Ethernet interfaces
16 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:1C:58:3C:90:00
Motherboard assembly number : 73-10316-11
Motherboard serial number : CAT11225MUH
Model revision number : B0
Motherboard revision number : A0
Model number : WS-C3750E-48PD-SF
Daughterboard assembly number : 800-28590-01
Daughterboard serial number : CAT112459R3
System serial number : CAT1125RG6A
Top Assembly Part Number : 800-28446-02
Top Assembly Revision Number : A0
Version ID : V01
CLEI Code Number : COM7D10ARA
Hardware Board Revision Number : 0x01
Switch 01
Switch Uptime : 10 hours, 57 minutes
Base ethernet MAC Address : 00:1D:A2:D7:11:80
Motherboard assembly number : 73-10316-12
Motherboard serial number : CAT11415990
Model revision number : C0
Daughterboard serial number : CAT11395352
System serial number : CAT1142R03M
Top assembly part number : 800-28446-02
Top assembly revision number : C0
Version ID : V01
License Level : ipbase
License Type : Permanent
Next reboot licensing Level : ipbase
Switch 02
Switch Uptime : 11 hours, 1 minute
Base ethernet MAC Address : 00:1B:D4:CE:61:80
Motherboard serial number : CAT1114550H
Model revision number : A0
Daughterboard serial number : CAT11175JFY
System serial number : CAT1118W04W
Top assembly revision number : A0
Version ID : V01
Switch 03
Base ethernet MAC Address : F4:AC:C1:81:F0:80
Motherboard assembly number : 73-11174-13
Motherboard serial number : FDO134300L3
Model revision number : F0
Daughterboard assembly number : 800-29737-01
Daughterboard serial number : FDO13410H44
System serial number : FDO1342V0PK
Top assembly part number : 800-28918-01
Top assembly revision number : B0
Version ID : V03
CLEI Code Number : COM9X10ARB
Switch 04
Switch Uptime : 11 hours, 8 minutes
Base ethernet MAC Address : 00:26:99:C4:2A:00
Motherboard serial number : FDO134301CN
Daughterboard serial number : FDO13420ZW5
System serial number : FDO1342V0SW
Version ID : V03
Switch 05
Switch Uptime : 11 hours, 0 minutes
Base ethernet MAC Address : 00:1C:58:3C:A0:80
Motherboard serial number : CAT11225MPS
Daughterboard serial number : CAT11245DYS
System serial number : CAT1125RG5M
Version ID : V01
Switch 07
Base ethernet MAC Address : 00:22:90:67:2F:00
Motherboard serial number : FDO122806PD
Model revision number : E0
Daughterboard assembly number : 73-9989-05
Daughterboard serial number : FDO12270L89
System serial number : FDO1229V0AS
Top assembly part number : 800-28446-04
Version ID : V02
CLEI Code Number : COM9X10ARA
Switch 08
Base ethernet MAC Address : 00:1B:D4:CE:50:80
Motherboard serial number : CAT1114550C
Daughterboard serial number : CAT11175JL3
System serial number : CAT1118W047
Version ID : V01
Configuration register is 0xF
07-06-2017 01:41 PM
The output to the "sh version" tells me different members of the stack rebooted due to "power on" which could potentially mean a power problem.
Can you post the complete output to the command "dir flash5:".
07-06-2017 02:06 PM
First of all thank you for spending your time checking my issue here.
Those eight switches distributed on 3 UPSs and I have another two stand alone switches who are using same UPSs and yet they do not reboot so I am pretty sure its not power issue.
Master switch changed today again since it got its daily reboot :( .
if you want crash info files I can provide them as well.
Switch/Stack Mac Address : 001d.a2d7.1180
H/W Current
Switch# Role Mac Address Priority Version State
*1 Master 001d.a2d7.1180 8 1 Ready
2 Member 001b.d4ce.6180 4 1 Ready
3 Member f4ac.c181.f080 6 1 Ready
4 Member 0026.99c4.2a00 9 1 Ready
5 Member 001c.583c.a080 12 1 Ready
6 Member 001c.583c.9000 13 1 Ready
7 Member 0022.9067.2f00 14 1 Ready
8 Member 001b.d4ce.5080 15 1 Ready
BOOTLDR: C3750E Boot Loader (C3750E-HBOOT-M) Version 12.2(35r)SE1, RELEASE SOFTWARE (fc2)
uptime is 19 hours, 23 minutes
System restarted at 20:38:31 CDT Wed Jul 5 2017
export@cisco.com.
cisco WS-C3750E-48PD (PowerPC405) processor (revision C0) with 262144K bytes of memory.
Processor board ID CAT1142R03M
Top Assembly Revision Number : C0
Version ID : V01
* 1 54 WS-C3750E-48PD 15.0(2)SE10a C3750E-IPBASEK9-M
Switch 02
Switch Uptime : 19 hours, 26 minutes
Version ID : V01
Switch 03
Switch Uptime : 19 hours, 23 minutes
Version ID : V03
Switch 04
Switch Uptime : 4 hours, 32 minutes
Version ID : V03
Switch 05
Switch Uptime : 4 hours, 33 minutes
Version ID : V01
Switch 06
Version ID : V01
Switch 07
Switch Uptime : 4 hours, 30 minutes
Version ID : V02
Switch 08
Version ID : V01
Directory of flash:/
2 -rwx 20437248 Mar 29 2011 20:37:40 -05:00 c3750e-universalk9-mz.150-2.SE8.bin
3 -rwx 152413 Jul 3 2017 08:09:50 -05:00 config.text
4 -rwx 2004 Jul 5 2017 20:41:01 -05:00 vlan.dat
5 -rwx 20439040 Jun 27 2017 09:03:20 -05:00 c3750e-ipbasek9-mz.150-2.SE10a.bin
6 drwx 512 Jun 27 2017 08:46:16 -05:00 c3750e-universal-mz.122-35.SE5
509 -rwx 8725 Jul 3 2017 08:09:52 -05:00 private-config.text
510 -rwx 5819 Jan 30 2013 07:12:04 -06:00 express_setup.debug
511 -rwx 152613 Jul 3 2017 08:04:13 -05:00 config.text.backup
512 -rwx 8725 Jul 3 2017 08:04:16 -05:00 private-config.text.backup
513 drwx 512 Jun 24 2017 11:27:19 -05:00 crashinfo_ext
520 -rwx 2072 Jul 6 2017 11:27:29 -05:00 multiple-fs
521 drwx 512 Jan 1 2006 18:00:05 -06:00 crashinfo
57409536 bytes total (11755008 bytes free)
Directory of flash5:/
2 -rwx 8725 Jul 3 2017 08:09:51 -05:00 private-config.text
3 -rwx 108 Dec 16 2009 17:33:29 -06:00 info
4 -rwx 2004 Jul 6 2017 11:30:08 -05:00 vlan.dat
5 -rwx 20439040 Jun 27 2017 08:23:37 -05:00 c3750e-ipbasek9-mz.150-2.SE10a.bin
6 -rwx 20437248 Sep 13 2011 19:05:16 -05:00 c3750e-universalk9-mz.150-2.SE8.bin
7 d--- 512 Dec 31 1969 18:00:25 -06:00 lost+found
10 drwx 1536 Aug 7 2012 19:15:54 -05:00 crashinfo_ext
29 drwx 1536 Feb 28 1993 18:00:19 -06:00 crashinfo
53 -rwx 2072 Jul 6 2017 11:30:13 -05:00 multiple-fs
47 -rwx 3458 Mar 29 2011 20:31:33 -05:00 express_setup.debug
48 -rwx 152413 Jul 3 2017 08:09:50 -05:00 config.text
49 -rwx 152613 Jul 3 2017 08:04:13 -05:00 config.text.backup
50 -rwx 8725 Jul 3 2017 08:04:15 -05:00 private-config.text.backup
57409536 bytes total (11644416 bytes free)
07-06-2017 04:39 PM
Yes, please attach the latest crashinfo files.
07-07-2017 07:05 AM
we just split / reduced the stack to four switches only lets wait this weekend and I will let you know what is the update.
Thank you again.
Mudher Alattar,
07-08-2017 08:11 AM
Even when we shrunk the stack to four switches only it got rebooted at the same time yesterday :
I am attaching the crashinfo files for your review.
Rogerdale-3750-40-49 uptime is 2 days, 13 hours, 32 minutes
System returned to ROM by address error at PC 0x58BBB4, address 0x0
System restarted at 20:34:56 CDT Wed Jul 5 2017
export@cisco.com.
cisco WS-C3750E-48PD (PowerPC405) processor (revision A0) with 262144K bytes of memory.
Processor board ID CAT1118W04W
Last reset from address error
Version ID : V01
* 2 54 WS-C3750E-48PD 15.0(2)SE10a C3750E-IPBASEK9-M
Switch 01
Switch Uptime : 22 hours, 40 minutes
Version ID : V01
Switch 03
Switch Uptime : 22 hours, 38 minutes
Version ID : V03
Switch 04
Version ID : V03
