3850 radius issue
aytekin.done
We have four 3850 switch as stack.
Versions
WS-C3850-48T       03.06.06E
WS-C3850-48P       03.06.06E
İ  configured aaa on 3850 as following
aaa new-model
aaa group server radius x
server name x
server name x
deadtime 1
aaa authentication login default group radius local
aaa authentication login NO none
aaa authentication dot1x default group x
aaa authorization exec default group x local if-authenticated
aaa authorization network default group x
aaa accounting dot1x network start-stop group x
aaa session-id common
İ  configured switchport as following
switchport access vlan x
switchport mode access
authentication control-direction in
authentication port-control auto
dot1x pae authenticator
storm-control broadcast level 50.00
storm-control action shutdown
spanning-tree portfast
i have Microsoft nps and other switchs have same config
there is no problem
but clients on 3850 dont authenticate and
I get an error like this in the logs
dot1x-5-result override authentication result overridden for client
i think the cause of this error is switch version
can you help me about this issue
thanks
Beith12
Hi, just worked on a near identical issue and it turned out to be the NPS configuration. Cisco 3560 switches seemed to operate fine but when swapped for 3850 switches the dot1x response would be reversed by the switch (NPS accepted the request).
