Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3631 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5316 Views
  • 1 replies
  • 16 Helpful votes
hi, in sg500 default all ports in native vlan are trunk. i have configured 2 vlans and set all ports as access. To connect switch with second switch i need one trunk port . Should i change all other ports to access in native vlan ? Do you create a  l...
Mk11 by Level 1
  • 1686 Views
  • 1 replies
I have two SG300-28P (SRW2024P) switches and one seems to be dead.  When plugged in, the fans turn on, the power comes on, and the port LEDs light for a split second just like it is supposed to do.  But, there is no console response and one, sometime...
I worked as an IT Admin in a school and we have to renew our L3 switches.   I have used previously in some little sites SG300-52 or 28 and i know the TCAM ressources are limited (around 500 entries if i remember).   I'v difficulties to find these val...
epersan by Level 1
  • 1733 Views
  • 4 replies
Hi All,   We are trying to implement dot1x on our SG300 switches. We where able to implement dynamic vlan assignment but we try to implement some extra commands for specific type of devices. On catalyst we would implement this by using auto smartport...
cisco by Level 1
  • 748 Views
  • 1 replies
I've been using the SD2005 for a while now.  Nothing physically has changed as far as cabling.  No new hardware has been added.   I'm unaware of any software auto update, but it's possible that the connection that's causing the problem has auto updat...
Grigori by Level 1
  • 728 Views
  • 1 replies
Hello All I have SG300 Switch and i use it as L3 (Core switch) ,There are 12 switch is connected to it.   I have 3 Vlans   My problem is i got a message (%ARPARPTBL: ARP Table Overflow, aggregated (9)   My TCAM   IPV4 Routing      in use 128 IPV4 Rou...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
