After some time can't get access to SG200 via WEB interface (management address).
smarts_09
Hello !
May be someone faced with following problem:
I have just upgraded my SG200-26P up to 1.4.1.03 version.
When SG200 just started it works OK and no any problems but after some hours I can't get access Web interface via mangement address.
I can't ping it at all :((( And only reboot switch help me to restore connectivity.
I will appreciate for any ideas.
Glenn Martin
How many SG200's do you have?
Was this issue experienced prior to the upgrade?
Did you remove all configurations and start over?
Hello Martin !
I have one SG200-26P and we have just bought another one SG200-26FP but have not installed it yet.
No, I had not this issue before firmware ugrade.
I had FW version 1.1.2.0 and 3 days ago I made FW upgrade to 1.4.1.03.
Yesterday I rebooted SG200 a few times due to problem with access to web interface though I could ping my management address.
The main problem that SG200 is located 400 km from me and access to SG200 is very sensitive for me. It's a pitty that SG200 don't have console port. So, as my colleague was near SG200 yesterday I was able to reboot it using my colleague. Eventually I made downgrade FW to previos release v.1.4.0.88. And it still works fine.
We installed antoher one SG200-26FP. It was upgraded to 1.4.1.03 as well. But it's working without problem with current firmware.
