ARP Table Overflow
waleed.magdy
Hello All
I have SG300 Switch and i use it as L3 (Core switch) ,There are 12 switch is connected to it.
I have 3 Vlans
My problem is i got a message (%ARPARPTBL: ARP Table Overflow, aggregated (9)
My TCAM
IPV4 Routing      in use 128
IPV4 Routing      Maximum 128
What will happened if i edit the maximum entries
Does the problem will be solved or not ??
Can anyone here help me
And if i purchased 3750 or 3850 this problem will be solved or not ??
5 Replies 5
Iliya Gatsev
My name is Iliya Gatsev from Cisco Technical Support Team.
Please let me know what is the current firmware and boot code version ?
Iliya Gatsev
Cisco STAC Network Engineer
Together we are the human network .:|:.:|:. CISCO
Thank you for your reply
Firmware Version (Active Image)
1.3.5.58
1.3.5.06
Iliya Gatsev
Please let me know what is the current boot code and firmware version ?
Iliya Gatsev
riteshsh
As per your query, the ARP table overflow error can be removed by increasing the TCAM Value.
Please increase the TCAM Value of the device and check if your issue is resolved or not.
Please rate this reply as useful if it resolves your issue.
Thank you riteshsh for your reply
Could you please determine the maximum number for the routed IP addresses as i have in my network about 350 host and i have WiFi guest users so does this switch can handle all of this??
Also all of these IPs will be joined to 4-5 VLANS
