05-10-2016 03:33 PM
I have something weird going on I can plug into one port (2) and get my full 100 down from my ISP and then plug into port (27) and get 10mbps down?
LAN to WAN Path
SG500 - Trunk - DELL 5448 - Trunk - Router
interface gigabitethernet1/1/2
spanning-tree link-type point-to-point
switchport mode access
macro description switch
!next command is internal.
macro auto smartport dynamic_type unknow
interface gigabitethernet1/1/27
storm-control broadcast enable
storm-control broadcast level 10
storm-control include-multicast
port security max 10
port security mode max-addresses
port security discard trap 60
spanning-tree portfast
macro description ip_phone
macro auto smartport dynamic_type unknown
05-12-2016 05:06 PM
It was the macro auto adding storm-control causing the bandwidth issue.
05-13-2016 07:14 AM
Nevermind its doing it again what is aggregated? I dont have Qos Enabled on the switch.
%LINK-I-Up: gi1/1/4, aggregated (1)
Same config on 2 ports are identical 3 is fast 4 is slow
switch32f1d0#show running-config int gi1/1/3
interface gigabitethernet1/1/3
no macro auto smartport
switch32f1d0#show running-config int gi1/1/4
interface gigabitethernet1/1/4
05-13-2016 07:41 AM
I ran the no lacp system-priority command and it fixed it. Why would LACP affect non port groups?
