05-28-2014 09:58 AM
After a factory reset I can no longer log in to the switch. This reset appeared to work, as the switch's IP changed back to factory default, and I can bring up the web interface there. It refuses to permit logins using either the old user/password combo or the default cisco/cisco combo. Any ideas?
05-28-2014 10:40 AM
Hi ,
After your factory reset , have you got assigned with IP address from 192.168.1.x segment , and you should reach the switch using 192.168.1.254 IP address .
Try reset-ing again and try with default username cisco and password cisco
Sandy
05-28-2014 10:54 AM
I appreciate the help. I am on the same segment (192.168.1.10/24) and can get to 192.168.1.254 fine.
A repeat reset results in the same inability to login.
