Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2873 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4429 Views
  • 1 replies
  • 16 Helpful votes
I have several SRW2024 switches and use the web admin interface to administer them. One of the switches recently started refusing any type of admin connection.I reset the system using the "reset" pin-hole on the front panel. I can now bring up the ad...
bobdye001 by Level 1
  • 1264 Views
  • 2 replies
These fatal errors and subsequent reboots are observed on my SG500-52P when I was reconfiguring the LAG ports on my server.I had the ports added to a LAG on the switch but the ports on the server were still just regular access ports.I was doing some ...
DJX995 by Level 3
  • 2032 Views
  • 8 replies
Hi,I was running firmware 1.1.2.0 and everything was working fine on 2 of these switches, connected via fiber.  I tried upgrading to the latest firmware (1.3.5.58) and had no luck.  Our phones which are Avaya 9650 VOIP handsets could not find the rou...
I have a CISCO SF 300-24, layer 2 switch. I have configured first 10 ports as VLAN 10, second 10 as VLAN 20 and rest as VLAN 30. There are three PCs on VLAN 10 and three on VLAN 20. I want one PC on VLAN 10 (IP: 193.156.26.111 mask: 255.255.255.0) to...
Hi there,I just bought a SG200-08 for my home network. I mainly bought it for the port channel/LACP and VLAN features. However, I'd also like to toy with SNMP. Both the data sheet and model comparison page mention that the SG200-08 supports SNMP, but...
I have a Cisco SGE200 which is part of a LAN. The whole switch comes under a VLAN. I have systems connected to it accessing other VLANs and the Internet. However, I have forgotten its user credentials and am not able to login. Since it doesn't have a...
Hi, I am running customer wifi on optional port, dmz.  We have been having problems with people not being able to connect to the wireless.  When I check the DMZ DHCP clients list it is showing about 120 people connected.  I don't think that it is rel...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
