08-01-2017 06:13 AM
Hi I'm currently running a Cisco SG300-28 28 port Gigabit Managed switch, when I try to upgrade the firmware it gives an error: copy:SW code file is over sized.
Can anybody assist?
Emmanuel
08-01-2017 07:44 AM
what version are you coming from too ? unlike catalyst there are jump versions on these platforms that you need to go to first before going to direct to some images , you could try another earlier image first and work your way up to the newer one if its jumping through multiple images
04-06-2018 05:38 PM
Currently running 1.3.7.18. I cannot update to a more recent image as no matter what "interim" image I select I always get the over-sized error
06-19-2018 07:39 PM
I have encountered the same problem now, and my current version wants to upgrade to 1.4.0.88 1.4.1.03 or the updated version will have an error message
06-20-2018 01:21 AM
Hello JHB and Hulk,
You need to upgrade the boot code also. The latest boot code is 1.3.5.06.
You can download it here:
https://software.cisco.com/download/home/283019669/type/282463181/release/1.3.5.58
Cheers,
Mike
06-20-2018 01:30 AM
Hi,mipopov
Thank you for reply,I saw the process of upgrading from an older version in another discussion, and then I have successfully upgraded to the latest version. Thank you very much.
Hulk
