04-14-2021 04:11 AM
Dear Sir or Madame,
Please confirm that in the CBS350-24T-4X we can use an SFP (1G) module into the SFP+ (10G) ports. I cant seem to find the related documentation that indicates this. SFP+ ports usually support also SFP modules but I need this to be confirmed in order to avoid suprises in the deployment.
Thank you in advance.
Best Regards,
Evi Kastania
Solved! Go to Solution.
04-14-2021 05:05 AM
Hi Evi,
Yes, you can use 1G SFP with the SFP+ port. The administrative port speed of each XG port can be changed to 1G and 10G. You can also refer to the product online device emulator page to become more familiar with the product web GUI look and feel and also see all the feature-functionalities on that device.
Martin
04-14-2021 05:05 AM
Hi Evi,
Martin
