CBS350-8P-E-2G (PoE port issues after lightning strike outside house)
qutihp4lyf
My house took a possible lightning strike and now my switch will not power my PoE WiFi AP. I tried every command I could think of for PoE configuraiton, but cannot get the ports to work for PoE. Everything else is fine and no issues with non-PoE devices.
I used the Command Guide for PoE configurations, but nothing worked. Here is what I have configured on the switchports, including trying different ones. Also is the Power output. Any assistance would be greatly appreciated!
hostname#show power inline
Power-limit mode: Port based
Usage threshold: 95%
Trap: Disable
Legacy Mode: Enable
Inrush Test: Enable
Guard-Band Value: Static (2W)
Unit Module Nominal Consumed Temp SW PSE chipset
Power (W) Power (W) (C) Version HW Revision
1 CBS350-8P-E-2G 60 0 (0%) 0 0.2.0.34
Interface Admin Oper Power (W) Class Device Priority
gi1 Auto Off 0.0 - critical
gi2 Auto Off 0.0 - low
gi3 Auto Off 0.0 - low
gi4 Auto Off 0.0 - critical
gi5 Auto Off 0.0 - low
gi6 Auto Off 0.0 - low
gi7 Auto Off 0.0 - low
gi8 Auto Off 0.0 - critical
hostname#show power inline gi1
Port Status: Port is off. Disabled by user setting
Port standard: 802.3AT
Admin power limit: 30.0 watts
Time range:
Operational power limit: 30.0 watts
Negotiated power: 0.0 watts (None)
Current (mA): 0
Voltage(V): 0.0
Overload Counter: 0
Short Counter: 0
Denied Counter: 0
Absent Counter: 0
Invalid Signature Counter: 0
hostname#show power inline gi4
Time range:
Current (mA): 0
Voltage(V): 0.0
Overload Counter: 0
Short Counter: 0
Denied Counter: 0
Absent Counter: 0
hostname#show power inline gi8
Time range:
Current (mA): 0
Voltage(V): 0.0
Overload Counter: 0
Short Counter: 0
Denied Counter: 0
Absent Counter: 0
hostname#
marce1000
 - Try factory reset , but possibly the device got broken and needs to be replaced (RMA)  ,
 M.
M02@rt37
Hello @qutihp4lyf,
If you continue to experience issues despite of #power inline auto command on interfaces, it's possible that the lightning strike may have damaged the PoE capabilities of your switch, and it may be necessary to initiate the RMA process with the manufacturer or vendor of the switch.
Best regards
