CBS350 and trunk port for CBW150AX
KSquared
I have a CBS350 that I'm trying to configure gig ether port 16 as a trunk port to support a CBW150AX with three SSIDs which correspond to three of my four VLANs (Guest, Reception, Office). Right now the CBW150AX boots (I get the blue LED showing it's booted) and it shows in the DHCP leased address list. But I can't access the config page from an access port on any of the three VLANs it's supposed to be on nor do I get a DHCP address or internet when connecting to a broadcast IP address.
I thought I understood the process but I guess not. I'm sure I'm missing something easy but my forehead is bruised and bloody from beating it against the wall. Show run and ge16 port config shown below.
I'd be greatly appreciative of any help pointing me in the right direction to solve this.
switch90cc82#show run
config-file-header
switch90cc82
v3.0.0.69 / RCBS3.0_930_770_008
CLI v1.0
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
unit-type-control-start
unit-type unit 1 network gi uplink none
unit-type-control-end
vlan database
vlan 10,20,30,40
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone
voice vlan oui-table add 00036b Cisco_phone
voice vlan oui-table add 00096e Avaya
voice vlan oui-table add 000fe2 H3C_Aolynk
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone
voice vlan oui-table add 00e075 Polycom/Veritel_phone
voice vlan oui-table add 00e0bb 3Com_phone
ip dhcp server
ip dhcp pool network Pool10
address low 192.168.10.100 high 192.168.10.199 255.255.255.0
default-router 192.168.10.1
dns-server 9.9.9.9
exit
ip dhcp pool network Pool20
address low 192.168.20.100 high 192.168.20.199 255.255.255.0
default-router 192.168.20.1
dns-server 9.9.9.9
exit
ip dhcp pool network Pool30
address low 192.168.30.100 high 192.168.30.199 255.255.255.0
default-router 192.168.30.1
dns-server 9.9.9.9
exit
ip dhcp pool network Pool40
address low 192.168.40.100 high 192.168.40.199 255.255.255.0
default-router 192.168.40.1
dns-server 9.9.9.9
exit
bonjour interface range vlan 1
hostname switch90cc82
username ********
username ********
clock timezone ET -5
clock summer-time web recurring usa
clock source browser
ip name-server 9.9.9.9
interface vlan 1
ip address 192.168.1.2 255.255.255.0
no ip address dhcp
interface vlan 10
name MasonGuest
ip address 192.168.10.2 255.255.255.0
interface vlan 20
name MasonReception
ip address 192.168.20.2 255.255.255.0
interface vlan 30
name MasonOffice
ip address 192.168.30.2 255.255.255.0
interface vlan 40
name MasonAdmin
ip address 192.168.40.2 255.255.255.0
interface GigabitEthernet1
switchport access vlan 10
interface GigabitEthernet2
switchport access vlan 20
interface GigabitEthernet3
switchport access vlan 30
interface GigabitEthernet4
switchport access vlan 40
interface GigabitEthernet5
interface GigabitEthernet6
interface GigabitEthernet7
interface GigabitEthernet8
interface GigabitEthernet14
switchport mode trunk
interface GigabitEthernet15
interface GigabitEthernet16
exit
macro auto disabled
macro auto processing type ip_phone disabled
macro auto processing type ip_phone_desktop disabled
macro auto processing type router enabled
ip default-gateway 192.168.10.1
ip default-gateway 192.168.20.1
ip default-gateway 192.168.30.1
ip default-gateway 192.168.40.1
switch90cc82#show interfaces switchport ge16
S-VLAN Ethernet Type: 0x8100 (802.1q)
VLAN Mapping Tunnel L2 protocols Global CoS: 5
Switchport: enable
Administrative Mode: trunk
Operational Mode: up
Access Mode VLAN: 1
Access Multicast TV VLAN: none
Trunking Native Mode VLAN: 1
Trunking VLANs: 1,10,20,30,40
2-9,11-19,21-29,31-39,41-4094 (Inactive)
General PVID: 1
General VLANs: none
General Egress Tagged VLANs: none
General Forbidden VLANs: none
General Ingress Filtering: enabled
General Acceptable Frame Type: all
General GVRP status: disabled
Customer Mode VLAN: none
Customer Multicast TV VLANs: none
Private-vlan promiscuous-association primary VLAN: none
Private-vlan promiscuous-association Secondary VLANs: none
Private-vlan host-association primary VLAN: none
Private-vlan host-association Secondary VLAN: none
VLAN Mapping Tunnel - no resources
VLAN Mapping One-To-One - no resources
Classification rules:
Classification type Group ID VLAN ID
0 Replies 0
