1000-8P-E-2G-L Power Supply
cactusman85
I recently purchase a Cisco Catalyst 1000-8P-E-2G-L and was wondering if it requires the 220V appliance plug that was in the box, or if that was a mistake and I should have received a 110V plug along with the power brick?
Or, should I purchase an Internal Power model (1000-8P-2G-L)?
It's been a long time since I have done any networking and I'm not sure if this is correct.
this model C1000-8P-E-2G-L  comes with external power supply. C1000-8P-2G-L is comes with internal power supply.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-1000-series-switches/nb-06-cat1k-ser-switch-ds-cte-en.html
power supply is auto ranging
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst1000/hardware/installation/8_16_port_hig/b_c1000_8_16_hig/technical_specifications.html#reference_hnh_gfg_g3b
Good luck
KB
cactusman85
So you are telling me that I should not be able to plug the C1000-8P-E-2G-L into a normal 110V outlet.
