CBS350 powered by PoE
cfetter
With the CBS350 replacing the SG350; will the smaller (8-port) units support being powered via PoE, PoE+, or PoE 60W? If so, will they also support any degree of PoE passthrough.
marce1000
 - Have a look at the datasheet (search for 'Power over Ethernet') :
          https://www.cisco.com/c/en/us/products/collateral/switches/business-350-series-managed-switches/datasheet-c78-744156.html
 M.
Martin Aleksandrov
Hi there,
60W PoE is supported on select RJ-45 network ports on select models (https://www.cisco.com/c/en/us/products/collateral/switches/business-350-series-managed-switches/datasheet-c78-744156.html Power over Ethernet (PoE) section). Currently, we don't offer PoE powered device and PoE passthrough functionality with the CBS350 series switches, however, there might be upcoming models with that support.
Martin
