CDB Overflow on SG300-28
Raoul Thill
anyone has an idea how to fix the following errors, they first shown up when I upgraded to the latest firmware version 1.4.1.3 which released earlier this month:
26-May-2015 19:50:37 :%CDB-W-STCDBOVERFLOW: Overflow in startup CDB. offset = 262078, file end = 262080
26-May-2015 19:50:24 :%CDB-W-CDBOVERFLOW: Overflow in CDB, aggregated (340)
26-May-2015 19:50:24 :%CDB-W-STCDBOVERFLOW: Overflow in startup CDB. offset = 262078, file end = 262080, aggregated (340)
26-May-2015 19:45:30 :%CDB-W-CDBOVERFLOW: Overflow in CDB
26-May-2015 19:45:30 :%CDB-W-STCDBOVERFLOW: Overflow in startup CDB. offset = 262078, file end = 262080
26-May-2015 19:45:29 :%CDB-W-CDBOVERFLOW: Overflow in CDB, aggregated (141)
26-May-2015 19:45:29 :%CDB-W-STCDBOVERFLOW: Overflow in startup CDB. offset = 262078, file end = 262080, aggregated (141)
Thanks for any hint.
Michael Vandergrift
Raoul,
Check out the link below.  Make sure you are on the most current bootcode for the SG300 (1.3.5.06) and that your STP root bridge is your core switch.  Please post your topology for further troubleshooting.  Thanks.
https://supportforums.cisco.com/discussion/11625086/sg200-bringing-down-network
Mike.V
Hi Mike,
thanks for your answer, but I am running the correct version and this switch has also the STP root:
SG300-28#27-May-2015 16:17:20 %CDB-W-STCDBOVERFLOW: Overflow in startup CDB. offset = 262078, file end = 262080
27-May-2015 16:17:20 %CDB-W-CDBOVERFLOW: Overflow in CDB
sh ver
SW version    1.4.1.3 ( date  29-Mar-2015 time  16:24:16 )
Boot version    1.3.5.06 ( date  21-Jul-2013 time  15:12:10 )
HW version    V02
SG300-28#sh spanning-tree
Spanning tree enabled mode RSTP
Default port cost method:  long
Loopback guard:   Disabled
  Root ID    Priority    32768
             Address     34:a8:4e:04:9f:0c
             This switch is the root
             Hello Time  2 sec  Max Age 20 sec  Forward Delay 15 sec
  Number of topology changes 0 last change occurred 361:03:51 ago
  Times:  hold 1, topology change 35, notification 2
          hello 2, max age 20, forward delay 15
Interfaces
  Name     State   Prio.Nbr    Cost    Sts   Role PortFast       Type
   gi1    enabled   128.49   2000000   Dsbl  Dsbl    No            -
   gi2    enabled   128.50    20000    Frw   Desg   Yes       P2P (RSTP)
   gi3    enabled   128.51    20000    Frw   Desg   Yes       P2P (RSTP)
   gi4    enabled   128.52   2000000   Dsbl  Dsbl    No            -
   gi5    enabled   128.53    200000   Frw   Desg   Yes       P2P (RSTP)
   gi6    enabled   128.54   2000000   Dsbl  Dsbl    No            -
   gi7    enabled   128.55    200000   Frw   Desg   Yes       P2P (RSTP)
   gi8    enabled   128.56    200000   Frw   Desg   Yes       P2P (RSTP)
   gi9    enabled   128.57    200000   Frw   Desg   Yes       P2P (RSTP)
  gi10    enabled   128.58   2000000   Dsbl  Dsbl    No            -
  gi11    enabled   128.59   2000000   Dsbl  Dsbl    No            -
  gi12    enabled   128.60   2000000   Dsbl  Dsbl    No            -
  gi13    enabled   128.61    200000   Frw   Desg   Yes       P2P (RSTP)
  gi14    enabled   128.62   2000000   Dsbl  Dsbl    No            -
  gi15    enabled   128.63    20000    Frw   Desg   Yes       P2P (RSTP)
  gi16    enabled   128.64    200000   Frw   Desg   Yes       P2P (RSTP)
  gi17    enabled   128.65    200000   Frw   Desg   Yes       P2P (RSTP)
  gi18    enabled   128.66    200000   Frw   Desg   Yes       P2P (RSTP)
  gi19    enabled   128.67    200000   Frw   Desg   Yes       P2P (RSTP)
  gi20    enabled   128.68    200000   Frw   Desg   Yes       P2P (RSTP)
  gi21    enabled   128.69    200000   Frw   Desg   Yes       P2P (RSTP)
  gi22    enabled   128.70    200000   Frw   Desg   Yes       P2P (RSTP)
  gi23    enabled   128.71    200000   Frw   Desg   Yes       P2P (RSTP)
  gi24    enabled   128.72    200000   Frw   Desg   Yes       P2P (RSTP)
  gi25    enabled   128.73    200000   Frw   Desg   Yes       P2P (RSTP)
  gi26    enabled   128.74   2000000   Dsbl  Dsbl    No            -
  gi27    enabled   128.75    20000    Frw   Desg   Yes       P2P (RSTP)
  gi28    enabled   128.76    20000    Frw   Desg   Yes       P2P (RSTP)
   Po1    enabled  128.1000   20000    Dsbl  Dsbl    No            -
   Po2    enabled  128.1001   20000    Dsbl  Dsbl    No            -
   Po3    enabled  128.1002   20000    Dsbl  Dsbl    No            -
   Po4    enabled  128.1003   20000    Dsbl  Dsbl    No            -
   Po5    enabled  128.1004   20000    Dsbl  Dsbl    No            -
   Po6    enabled  128.1005   20000    Dsbl  Dsbl    No            -
   Po7    enabled  128.1006   20000    Dsbl  Dsbl    No            -
   Po8    enabled  128.1007   20000    Dsbl  Dsbl    No            -
SG300-28#
Do you have any other ideas to look at?
I am still getting those messages every 5 minutes. How could I open a bug report for this product?
Jun 18 16:02:44 SG300-28 CDB %CDB-W-STCDBOVERFLOW: Overflow in startup CDB. offset = 262080, file end = 262080, aggregated (350)
Jun 18 16:02:44 SG300-28 CDB %CDB-W-CDBOVERFLOW: Overflow in CDB, aggregated (350)
Jun 18 16:07:44 SG300-28 CDB %CDB-W-STCDBOVERFLOW: Overflow in startup CDB. offset = 262080, file end = 262080, aggregated (337)
Jun 18 16:07:44 SG300-28 CDB %CDB-W-CDBOVERFLOW: Overflow in CDB, aggregated (337)
Jun 18 16:07:49 SG300-28 CDB %CDB-W-STCDBOVERFLOW: Overflow in startup CDB. offset = 262080, file end = 262080
Jun 18 16:07:49 SG300-28 CDB %CDB-W-CDBOVERFLOW: Overflow in CDB
Jun 18 16:12:49 SG300-28 CDB %CDB-W-STCDBOVERFLOW: Overflow in startup CDB. offset = 262080, file end = 262080, aggregated (351)
Jun 18 16:12:49 SG300-28 CDB %CDB-W-CDBOVERFLOW: Overflow in CDB, aggregated (351)
Jun 18 16:17:49 SG300-28 CDB %CDB-W-STCDBOVERFLOW: Overflow in startup CDB. offset = 262080, file end = 262080, aggregated (335)
Jun 18 16:17:49 SG300-28 CDB %CDB-W-CDBOVERFLOW: Overflow in CDB, aggregated (335)
Jun 18 16:17:53 SG300-28 CDB %CDB-W-STCDBOVERFLOW: Overflow in startup CDB. offset = 262080, file end = 262080
Jun 18 16:17:53 SG300-28 CDB %CDB-W-CDBOVERFLOW: Overflow in CDB
Jun 18 16:22:53 SG300-28 CDB %CDB-W-STCDBOVERFLOW: Overflow in startup CDB. offset = 262080, file end = 262080, aggregated (351)
Jun 18 16:22:53 SG300-28 CDB %CDB-W-CDBOVERFLOW: Overflow in CDB, aggregated (351)
Jun 18 16:27:53 SG300-28 CDB %CDB-W-STCDBOVERFLOW: Overflow in startup CDB. offset = 262080, file end = 262080, aggregated (334)
Jun 18 16:27:53 SG300-28 CDB %CDB-W-CDBOVERFLOW: Overflow in CDB, aggregated (334)
Jun 18 16:27:56 SG300-28 CDB %CDB-W-STCDBOVERFLOW: Overflow in startup CDB. offset = 262080, file end = 262080
Jun 18 16:27:56 SG300-28 CDB %CDB-W-CDBOVERFLOW: Overflow in CDB
Jun 18 16:32:56 SG300-28 CDB %CDB-W-STCDBOVERFLOW: Overflow in startup CDB. offset = 262080, file end = 262080, aggregated (351)
Jun 18 16:32:56 SG300-28 CDB %CDB-W-CDBOVERFLOW: Overflow in CDB, aggregated (351)
Jun 18 16:32:57 SG300-28 CDB %CDB-W-STCDBOVERFLOW: Overflow in startup CDB. offset = 262080, file end = 262080
Jun 18 16:32:57 SG300-28 CDB %CDB-W-CDBOVERFLOW: Overflow in CDB
Jun 18 16:37:57 SG300-28 CDB %CDB-W-STCDBOVERFLOW: Overflow in startup CDB. offset = 262080, file end = 262080, aggregated (340)
Jun 18 16:37:57 SG300-28 CDB %CDB-W-CDBOVERFLOW: Overflow in CDB, aggregated (340)
Jun 18 16:38:03 SG300-28 CDB %CDB-W-STCDBOVERFLOW: Overflow in startup CDB. offset = 262080, file end = 262080
Jun 18 16:38:03 SG300-28 CDB %CDB-W-CDBOVERFLOW: Overflow in CDB
Jun 18 16:43:03 SG300-28 CDB %CDB-W-STCDBOVERFLOW: Overflow in startup CDB. offset = 262080, file end = 262080, aggregated (350)
Jun 18 16:43:03 SG300-28 CDB %CDB-W-CDBOVERFLOW: Overflow in CDB, aggregated (350)
Jun 18 16:48:03 SG300-28 CDB %CDB-W-STCDBOVERFLOW: Overflow in startup CDB. offset = 262080, file end = 262080, aggregated (333)
Jun 18 16:48:03 SG300-28 CDB %CDB-W-CDBOVERFLOW: Overflow in CDB, aggregated (333)
Jun 18 16:48:06 SG300-28 CDB %CDB-W-STCDBOVERFLOW: Overflow in startup CDB. offset = 262080, file end = 262080
Jun 18 16:48:06 SG300-28 CDB %CDB-W-CDBOVERFLOW: Overflow in CDB
Jun 18 16:53:06 SG300-28 CDB %CDB-W-STCDBOVERFLOW: Overflow in startup CDB. offset = 262080, file end = 262080, aggregated (350)
Jun 18 16:53:06 SG300-28 CDB %CDB-W-CDBOVERFLOW: Overflow in CDB, aggregated (350)
Jun 18 16:58:06 SG300-28 CDB %CDB-W-STCDBOVERFLOW: Overflow in startup CDB. offset = 262080, file end = 262080, aggregated (340)
Jun 18 16:58:06 SG300-28 CDB %CDB-W-CDBOVERFLOW: Overflow in CDB, aggregated (340)
Jun 18 16:58:12 SG300-28 CDB %CDB-W-STCDBOVERFLOW: Overflow in startup CDB. offset = 262080, file end = 262080
Jun 18 16:58:12 SG300-28 CDB %CDB-W-CDBOVERFLOW: Overflow in CDB
Jun 18 17:03:12 SG300-28 CDB %CDB-W-STCDBOVERFLOW: Overflow in startup CDB. offset = 262080, file end = 262080, aggregated (350)
Jun 18 17:03:12 SG300-28 CDB %CDB-W-CDBOVERFLOW: Overflow in CDB, aggregated (350)
cycusphussus
Having the same problem. Running the latest firmware.
