Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 1490 Views
  • 1 replies
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant  - Discover support content and options for your gearSupport page index - Contains ...
  • 2931 Views
  • 1 replies
  • 15 Helpful votes
Hi,QoS Egress per shaping configuration at Cisco SF300/24 here Four (4) Queue Egress shaping 1,2,3,4 but why this Queue 1,2,3,4 and where to use?I am using each per port 6Mbps and Queue Egress shaping 1,2,3,4 use 6Mbps, 5Mbps,3Mbps, 2Mbps, it's work ...
Hi - my goal is to configure a private network (I need it isolated to use its own DHCP server, not my cable modem/router DHCP). I have this setup: internet connection -> cable modem (192.168.0.0/24) -> wifi mesh router (192.168.68.0/24) -> SG250-08. ...
mallmen00 by Beginner
  • 536 Views
  • 1 replies
Hi,  I have a switch SG250-50P 50-Port Gigabit PoE. I have 2 VLAN VLAN 1 : 192.168.10.XVLAN100 : 192.168.100.X I would like to enable VLAN routing in IP configuration, IPv4 routing is enable and i have 2 IP for my 2 VLANs. But i am unable to ping oth...
yvan74 by Beginner
  • 1196 Views
  • 17 replies
Hello, I have a SonicWall NSa 3700 firewall, Tripp-Lite KVM, and Cisco SG350XG-24T switch. I connected my Cisco switch OOB port to one of the firewall interfaces and the Tripp-Lite KVM to two firewall interface using Transparent IP Mode (Splice L3 Su...
alsayegh by Beginner
  • 419 Views
  • 2 replies
