changed default vlan - web UI no longer accessible
dgarcia
I changed my default vlan from 1 to 3 on my sg300 and now I can no longer access the web UI. I'm sure this is because I didn't properly set it up before making the change.
I am in the CLI but I cannot figure out how to simply revert back so I can access the web UI.
Attached is the show run. The web UI was accessible from 10.3.1.64. The 10.0.1.29 is a reflection of our old network. That IP also does not work for the web UI. Any help is much appreciated.
-Daniel
vinarumu
Hello Daniel,
Thanks for contacting Cisco support community centre.
I hope you are doing well. I am really sorry for inconvenience caused and delay in response. I see VLAN 3 is not created in switch and only VLAN 10 is allowed on all LAN ports. Please allow VLAN  1 on LAN ports (1 to 10) to regain the GUI access.
Please reach out our SBSC team and raise service request to proceed further.
You can contact our SBSC team via chat with the help of below links:
https://supportforums.cisco.com/community/4841/online-chat-support
Thank you, Vinarumu. That worked.
