Cisco 9300 Management IP
mrogers2024
Ladies/Gents:
I need to change the management IP of my 9300. Discovered I have a C1000 connected on the network with duplicate IP address.
Should start out by asking if I can do this via the CLI interface on the switch web GUI or can this only be accomplished via telnet?
Here are the commands I am attempting. It doesn't seem to like the line where I attempt to set the IP address.
It gives me the following error:
# ip address 192.168.87.2 255.255.255.0
% Invalid input detected at '^' marker.
I am starting out by entering "enable" before entering the following:
config t
interface vlan 1
ip address 192.168.87.2 255.255.255.0  (or whatever IP and mask you'd like)
exit
exit
copy run start
@mrogers2024
 You can do It using cli with console cable or Telnet /SSH. As long as you can login and execute command, you are fine.
 Not clear what the problem came from but If you run your script, It should work
config t
interface vlan 1
You should add
ip default-gateway "IP address"
