Cisco CBS350-48FP-4X: RxWatchdogTimeout: RX packet RX Watchdoch timer
indis
Hi Guys,
I connected three switch groups with a stack of 4, a single switch via CISCO DAC cable 1m and a stack of 2 via Cisco 10GbE SR transceiver in the PortChannel. The stack of 4 has the uplink to the MPLS router. There were no problems with the setup. Since the systems were migrated to the new switch, users have reported that their Cisco phones are rebooting and connections are being lost. What I can see on the switch: The PortChannel sometimes goes offline because the uplinks switch off. This happens with FiberChannel, as well as with DAC cables. If I'm lucky, only one port goes offline and the other port stays online. Port Down and Port Up usually happen in the same second.
22-Sep-2023 08:09:15 :%LINK-I-Up: Po1
22-Sep-2023 08:09:08 :%TRUNK-I-PORTADDED: Port te3/0/4 added to Po1
22-Sep-2023 08:09:08 :%LINK-W-Down: Po1
22-Sep-2023 08:08:44 :%TRUNK-W-PORTREMOVED: Port te3/0/4 removed from Po1
22-Sep-2023 08:08:36 :%LINK-I-Up: Po2
22-Sep-2023 08:08:27 :%LINK-I-Up: Po1
22-Sep-2023 08:08:27 :%TRUNK-I-PORTADDED: Port te3/0/4 added to Po1
22-Sep-2023 08:08:27 :%TRUNK-I-PORTADDED: Port te4/0/3 added to Po2
22-Sep-2023 08:08:20 :%LINK-W-Down: Po2
22-Sep-2023 08:08:20 :%LINK-W-Down: Po1
22-Sep-2023 08:08:13 :%TRUNK-W-PORTREMOVED: Port te4/0/3 removed from Po2
22-Sep-2023 08:08:13 :%TRUNK-W-PORTREMOVED: Port te3/0/4 removed from Po1
22-Sep-2023 08:08:13 :%TRUNK-W-PORTREMOVED: Port te1/0/4 removed from Po1
22-Sep-2023 08:08:13 :%TRUNK-W-PORTREMOVED: Port te1/0/3 removed from Po2
22-Sep-2023 07:55:56 :%TRUNK-I-PORTADDED: Port te3/0/4 added to Po1
22-Sep-2023 07:55:55 :%TRUNK-W-PORTREMOVED: Port te3/0/4 removed from Po1
22-Sep-2023 07:55:55 :%TRUNK-I-PORTADDED: Port te1/0/4 added to Po1
22-Sep-2023 07:55:55 :%TRUNK-I-PORTADDED: Port te1/0/3 added to Po2
22-Sep-2023 07:55:54 :%TRUNK-W-PORTREMOVED: Port te1/0/4 removed from Po1
22-Sep-2023 07:55:54 :%TRUNK-W-PORTREMOVED: Port te1/0/3 removed from Po2
I also get this error message every second during the day for several minute:
%HAL_config_main-A-RxWatchdogTimeout: RX packet Watchdog timer timeout. packet did not complete treatment for 120 seconds
Then I have about 2 hours of peace and it starts all over again. The failures are about 2-3 times a day. I've also tried different firmwares. The current version 3.3.0.16 is currently installed.
The WebFrontend always hangs or is very slow. It works somewhat over SSH, but the SSH connection keeps breaking. With the other switches I have no problems other than the ports going down (due to the port down on the 4 stack).
Does somebody has any idea?
Configuration:
spanning-tree priority 4096
vlan database
vlan 16-24,168
exit
voice vlan id 16
no eee enable
no bonjour enable
no ip http server
clock timezone CET +1
clock summer-time web recurring eu
interface vlan 1
no ip address dhcp
interface vlan 16
name VOIP
interface vlan 17
name LVS
interface vlan 18
name WLAN-Guest
interface vlan 19
name WLAN-Clients
interface vlan 20
name NetzwerkInfra
ip address X.X.X.10 255.255.255.0
interface vlan 21
name Drucker
interface vlan 22
name Kamera
interface vlan 23
name Devices/SCRAB
interface vlan 24
name WLAN-Konferenz
interface vlan 168
name LAN
interface GigabitEthernet1/0/1
description LAN
spanning-tree portfast
switchport mode trunk
switchport access vlan 168
switchport trunk native vlan 168
switchport trunk allowed vlan 16,168
interface GigabitEthernet1/0/25
description Drucker
switchport access vlan 21
interface GigabitEthernet1/0/31
description WLAN
switchport trunk native vlan 20
switchport trunk allowed vlan 17-21,23-24
interface GigabitEthernet1/0/39
description Kamera
switchport access vlan 22
interface GigabitEthernet1/0/45
description Devices
switchport access vlan 23
interface GigabitEthernet1/0/47
description VOIP-Router
no spanning-tree portfast
interface GigabitEthernet1/0/48
description "Uplink Plusnet"
switchport trunk native vlan 666
interface TenGigabitEthernet1/0/3
description "Uplink ko-switchtechnik02"
channel-group 2 mode auto
interface TenGigabitEthernet1/0/4
channel-group 1 mode auto
interface TenGigabitEthernet3/0/4
interface TenGigabitEthernet4/0/3
interface Port-Channel1
interface Port-Channel2
description "Uplink ko-switchlager01"
Best Regards
Daniel
marce1000
                 >...%HAL_config_main-A-RxWatchdogTimeout:
  - This might be indicative of a hardware issue ; power cycle the involved device and check if that changes anything ,
 M.
The switches have already been restarted. But I'll try turning off the power to the switch and restarting it again.
The devices was turned off and on again. The problem is still there.
D.
           - I would advice to RMA that particular box ,
 M.
