Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
Labels
Update: This portion of the project has finished earlier than initial projections. We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board fro...
CoreyP319 by Cisco Employee
  • 1262 Views
  • 0 replies
  • 1 Helpful votes
Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Installation Guide - Catalyst 1300Hardware Installation Guide - Catalyst 12...
  • 5970 Views
  • 4 replies
  • 17 Helpful votes
Hello everyone, trying to connect to switch via console.The switch has a DB9 socket as a console, I connect the serial cable to the PC via a USB adapter. In the PUTTY application, I select the appropriate COM3 port and the console is displayed, but I...
ReeQ by Level 1
  • 695 Views
  • 8 replies
Hello,  We have several CSB110-24T switches in our office that are working normally except the LED of the ports. When we connected the switch port to one end of a CAT5e cable (the other end doesn't connect to any device or patch panel), the LINK/ACT ...
Hi,Does the CBS350 support using the same data source(s) for multiple destination session definitions?I currently have a RSPAN destination configured using a VLAN source, and would like to use the same VLAN source for an additional SPAN destination s...
Dave K by Level 1
  • 3051 Views
  • 7 replies
Hello,During planned electricity poweroff - we had a strange issue with 2x SG200-50P switches. After electricity come back - our switches booted properly, but some devices were not powered through PoE (mostly IPTV camera). So we've tried different po...
Hello, I'm, running a SG350XG-24F with software Version 2.4.0.94 and got lots of the following log messages:   26-Oct-2018 04:44:00 :%Box-W-I2C-FAILURE-READ: I2C failed to read information from device at address 0x70 on bus 1 offset 0x09, component C...
jane1 by Level 1
  • 4185 Views
  • 3 replies
Hi everyone, I have two CBS350-48T-4X and I would like to stack them, my question is it possible using the Lan RJ-45 ports to configure the stack? When I'm doing the Stack configuration, it only allows me to select the 4x SFP ports. Is there an addit...
llima by Level 1
  • 1063 Views
  • 2 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
