Cisco cbs350 restrict ssh through ACL from particular IPs
cbeprem123
Hi All,
I followed this article to restrict ssh access , but still i am  not able to restrict ssh access . Kindly help with commands .
Configure Secure Shell (SSH) Server Authentication Settings on a Switch - Cisco
Prem.
@cbeprem123
 Pretty easy. This guide is for enable SSH, not restrict.
connect to your CBS350, on the top right corner select Advanced.
Go to the Security tab and them to
Access Profiles
On the Access Profile, use the Plus icon to create a new Access Profile.
Here you can select the protocol you want to restrict, You can apply to interface and choose IP address that will be permited
Not working buddy . thanks for replying
Can I see your config?
