08-09-2016 07:34 PM
Downloaded and installed Cisco Network Assistant. The interface is so small, the text is such small font that it's impossible to see anything. It's as if the resolution is detected as being 4 times larger than what it is. How can this be changed?
06-13-2019 02:12 PM
No Solutions from cisco but I got this to work for me running Network Assistant ver 6.3(4) on Windows 10 high res 4K monitor:
Right-click the Cisco Network Assistant shortcut
Compatibility
Change High DPI settings
Put a checkmark on "High DPI scaling override"
Change "Scaling Performed by" to:
System
or to
System (Enhanced).
Either one works for me. Good Luck!
06-30-2021 08:30 PM
Worked perfect. My only add, is I had to make the changes under "change settings for all users", as they were greyed out.
