08-14-2011 10:34 AM
Im trying to get my head around my new cisco SG 300 switch. Im not very experienced but I have used the Linksys SRW range before and configured it using teraterm and method described in the link below:
http://homecommunity.cisco.com/t5/Switches/SRW-series-super-secret-CLI-mode/td-p/109959
As im fimilar with this method and the commands ideally I'd like to use this on the SG 300 range as well. Is this possible?
Failing that, is it possible to use another method which uses the same commands which can be easily copy and pasted for setting up multiple switches with the configuration?
All help greatly appreicated,
Cheers
08-15-2011 07:35 AM
The older SRW CLI method is not particulary relevant to the new SG300 series switch.
If you had older, for example, a 8 port gig SRW2008 switch, that process that you referenced may have been relevant.
Today, if you buy a SRW2008-K9-NA switch, the K9 tells me that this switch is a newer 300 series switch, the NA tells me it's a North American power supply variety.
Note: We kept the ordering p/n of the 300 series switch similar, ( but not identical) to that of the older SRW switches for consistency reasons.
Having said that, the newer 300 series product is generations ahead of it's older ancestor, with a Ton more featuressuch as the option for IPv6 and Layer 3 switching.
I have attached the CLI reference guide for the 300 series switches firmware version 1.1
This CLI does enable the option for, as you suggest "easily copy and pasted for setting up multiple switches with the configuration?"
I have also included a link to the 300 series firmware version 1.1 CLI manual for your reference
http://www.cisco.com/en/US/products/ps10898/prod_command_reference_list.html
Hope this helps.
regards Dave
