Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco SG110-16HP switch POE spec
Alucidnation
Hi all,
I seem to have a bottleneck with my Linksys poe+ switch, so i am looking at replacing it with the
Cisco SG110-16HP
However, looking at the spec, it seems that it only support POE (af) and does not support POE+ (at)?.
Is this really the case, as i have seen online at various retailers that it is yet the cisco specs says otherwise?
http://www.broadbandbuyer.co.uk/products/22150-cisco-smb-sg110-16hp-uk/
Thanks for any help.
devils_advocate
Level 7
Level 7
This is from the Data Sheet:
Ports
10/100/1000 Ethernet, with support for 802.3af PoE, power port for AC adapter or power cord
There is no mention of PoE+ in the Data Sheet, therefore I can only assume its not supported.
As much as the Cisco Data Sheets may have the odd error, I would rather trust those than a vendor/reseller website.
The Data Sheet also says:
Power over Ethernet (PoE)
Model Name
SF110D-08HP
SF110D-16HP
SG110D-08HP
SG110-16HP
SG110-24HP
Power Dedicated to PoE
32 watts
64 watts
32 watts
64 watts
100 watts
Number of PoE Ports
12
64 Watts with 8 ports means a Maximum of 8w per port assuming all 8 ports in use.
My feeling is that PoE+ is not supported based on this.
Hi, yes i ddid wonder.
Do you knowif Cisco do a 16P POE+ switch?
I would like to use POE+ as this will mean my access points (2702) will get full power.
Look at the SG300/SG500 range.
Something like the SG300-28PP which gives 180w and supports PoE+
http://www.cisco.com/c/en/us/products/collateral/switches/small-business-smart-switches/data_sheet_c78-610061.html
Ok thanks, ill look into those.
