04-21-2015 03:39 AM
Hi all, I have 2 Cisco SG300-10 switches with MFEFX1 spf modules. Although these modules should be supported, it seems they are not working properly.
If I execute SH fiber-ports optical-transceiver I get
SwInter1#show fiber-ports optical-transceiver interface gi10
Port Temp Voltage Current Output Input LOS
Power Power
gi10 N/S N/S N/S N/S N/S N/S
Temp - Internally measured transceiver temperature
Voltage - Internally measured supply voltage
Current - Measured TX bias current
Output Power - Measured TX output power in milliWatts
Input Power - Measured RX received power in milliWatts
LOS - Loss of signal
N/A - Not Available, N/S - Not Supported, W - Warning, E - Error
Could you help me with this?
Thanks in advance
04-21-2015 06:37 AM
yes those sfps are supported , whats the led on the port show when there connected ?
Have you a spare cable incase the fibre is bad ? What does it show you under the view log and ip configuration section in the GUI when the sfps are connected ? Whats the current port configuration on each side
Regards Mark
04-22-2015 06:21 AM
Hi Mark,
The led is green, also the status is connected
SwInter1#sh interface status
Flow Link Back Mdix
Port Type Duplex Speed Neg ctrl State Pressure Mode
gi1 1G-Copper -- -- -- -- Down -- --
gi2 1G-Copper -- -- -- -- Down -- --
gi3 1G-Copper -- -- -- -- Down -- --
gi4 1G-Copper -- -- -- -- Down -- --
gi5 1G-Copper -- -- -- -- Down -- --
gi6 1G-Copper -- -- -- -- Down -- --
gi7 1G-Copper -- -- -- -- Down -- --
gi8 1G-Copper -- -- -- -- Down -- --
gi9 1G-Combo-C -- -- -- -- Down -- --
gi10 1G-Combo-F Full 100 Disabled Off Up Disabled Off
When I insert the spf module, this appears in the log
6-Mar-2014 19:04:22 %Fiber-I-SFP-PRESENT-CHNG: gi10 SFP status is present.
06-Mar-2014 19:04:23 %HAL_config_phy-I-CHNGCOMBOMEDIA: Media changed from copper
media to fiber media (Unknown) on port gi10.
06-Mar-2014 19:04:24 %LINK-I-Up: gi10
06-Mar-2014 19:04:24 %LINK-I-Up: Vlan 1
06-Mar-2014 19:04:29 %STP-W-PORTSTATUS: gi10: STP status Forwarding
The ports are simply configured with speed 100. It's being used only vlan 1.
04-22-2015 07:04 AM
Is there any logs further after spanning-tree goes into forwarding state when you connect the sfp , it show the interface come up , vlan come up , go into forwarding mode is there anything further ?
Is there any other physical connections connecting these 2 switches , just to rule out stp disabling the port due to l2 loop
Are you running the latest f/w 1.3.5.8
Do you get the same result if you connect by copper
04-22-2015 10:37 PM
There are no more logs after that and there are no other physical connections between these switches.
I'll try to upgrade the firmware, thanks.
I haven't tried yet with fiber converters. I hoped to avoid them. But I'll try.
04-23-2015 04:49 AM
Yes i would go with the fw upgrade first , the fact that your fiber output shows not supported but your led is green and connected doesn't seem right , even though Cisco say they support these sfps there seems to be a lot of different forums out there saying they have hardware/compatibility issues and not only on the sg300s but also on the srw models as well
good luck
04-23-2015 05:02 AM
This list also confirms your sfp is supported for sg300-10 as well so it has to be some compatibility issue , i have attached latest fw for you from last August
http://www.cisco.com/c/dam/en/us/td/docs/interfaces_modules/csbna/mgb/quick_start/guide/Optical_Module_QSG_en-US.pdf
