Cisco SG300-10P switch system light constantly flashing
Attiq
Hi everyone,
just today i have issue with SG300-10P system light is flashing constantly while three Ethernet ports are connected to switch and working, but i have doubt on switch might be its trying to boot but stuck in flash error. even i tried to connect through serial but failed to access.
please guide me what will be the possible reason..Thanks
Glenn Martin
Flashing amber LED typically means device is in Boot mode or the default 192.168.1.1 IP adress is being used. If you can't get it to boot I'd recommend reaching out to the Technical Services team for further assistance.
Glenn Martin
Thank Martin, for reply,
as you mentioned the device was on default IP  address 192.168.1.xx.
Glad it worked out for you...
