CE 500 Initial Configuration
fernandodonadio
I'm facing problems to configure a legacy CE 500.
I followed the procedure described below to reset the switch configuration:
1. Unplug the power cord from the switch.
2. Hold the setup button while you plug back in the power to the switch.
3. Wait until all LED indicator lights turn amber, and then release the button.
4. When a switch port LED blinks green, connect your PC to that port. The port LEDs on your PC and the switch blink green while the switch configures the connection. This takes about one minute.
5. Open a web browser. If the browser does not pull up the GUI automatically, then go to http://169.254.0.1 and configure the device.
6. Pull up the browser, and select either Erase system configuration item and click Submit.
After the switch was reseted to its factory default configuration, I should be able to access the web page to configure it, but I wasn´t.
Does anyone know what kind of issue is this and what need to be done to solve it?
Fernando
0 Replies 0
