Cisco SG300-20 Interface Syntax
Tyler Durden
Hi All
I'm writting some configurations for a new install and we do not have the hardware at present as we are waiting for delivery.
Can someone help me out and give me the correct port range syntax (for example)
Gigabit Interface 1/0/1
gi1/1
gi1
There are 20 ports on the SG300-20, I asume that port 19 and 20 are copper or Gbic using the CLI command #media type
Many thanks
Seb Rupik
Hi there,
The switchport syntax is Gi1, so you have:
int range gi1-20
Ports 19 and 20 are combo ports, they will default to the SFP port if it is connected. There is no need to configure media type.
sh int status
gi19     1G-Combo-C   Full    1000   Enabled  Off      Up      Disabled Auto
gi20     1G-Combo-C   Full    1000   Enabled  Off      Up      Disabled Auto
cheers,
Seb.
Seb Rupik
Hi there,
int range gi1-20
sh int status
cheers,
Seb.
Outstanding and thanks for the speedy reply :-)
