Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3030 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4612 Views
  • 1 replies
  • 16 Helpful votes
Good evening everyone,  I have had the misfortune to have never run into a SF300-48 before recently. It is a doozy of a CLI and GUI. I can't seem to get my ShoreTel phones and LAN working simultaneously and the configuration of this device is counte...
crowden by Level 1
  • 480 Views
  • 0 replies
Hello, I have a SG200 switch configured with 2 VLANs - VLAN 1: The standard VLAN on the switch (172.10.100.0/255.255.255.0).   Let's assume the client is connected to Port 5 on the switch. - VLAN 20: The VLAN id for wireless (172.10.200.0/255.255.255...
ertsandig by Level 1
  • 478 Views
  • 0 replies
Does anyone know if there's a way to reset the SC 100D 8 port switch?  My issue is that while this is a gigabit switch, I can not get over 100mbs on a speedtest for my network. As far as I can tell, there is no software or firmware that's upgradable ...
i did setup for gvrp in my two sf 300 switch: I enabled GVRP on the TRUNK ports  for all switches  I allowed all vlans on the TRUNK ports  I  enabled the GVRP globally i follow the instruction and applied in first and second switch,  but still i can...
Hello, I'm trying to solve a strange behaviour of my Smart Switch Gigabit SG 200-08. After 3 years of flawless use, ports no.1 and 2 suddenly went off. Front LEDs are off, and the port configuration webpage shows them labelled as "Inactive connectio...
diego by Level 1
  • 601 Views
  • 1 replies
Hello,I would like to ask, how is STP protocol implemented on small business series of switches ? Because when I type command "show spanning-tree" on catalyst switch, I see priority for example as 32768 + VLAN IDOn SMB switch I see just priority for ...
Attempting to create routed port between a pair of SG500x. Show run shows: set system queues-mode 4 GUI System Operation Mode: L3 and L2 mode Interface has IP address assigned. When I enter the no switchport command get incomplete command.  Options ...
emetesh by Level 1
  • 865 Views
  • 2 replies
Hi Team, Am doing a POC with FindIT Probe at customer place. Together with it, I have RV320 router and SG500 switch too. I was able to get a topology view on the RV320 and SG500. I have some questions. 1) I was not able to get meaningful representati...
derong by Cisco Employee
  • 989 Views
  • 6 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
