Cisco SG300 with Spicework via SSH
maxmakung
I tried to add Cisco SG300-28 into Spicework but it doesn't work at all.
What I did
- Enabled SSH and SNMPv1 and SNMPv3 (Spicework show it's connected but can't get switch information)
- Disabled Firewall in Windows7
- I can use Putty to download running-config and startup-up confing from this switch into TFTP in spicework
Firmware:
SW version    1.3.7.18 ( date  12-Jan-2014 time  18:02:59 )
Boot version    1.3.5.06 ( date  21-Jul-2013 time  15:12:10 )
HW version    V01
Switch log:
2014-Mar-27 09:05:06 Warning %SNMP-W-SNMPAUTHFAIL: Access attempted by unauthorized NMS
2014-Mar-27 09:05:06 Warning %AAA-W-REJECT: New ssh connection, source 10.2.101.13 destination 192.168.100.25  REJECTED, aggregated (2)
2014-Mar-27 09:04:32 Informational %AAA-I-DISCONNECT: User CLI session for user cisco over ssh , source 10.2.101.13 destination  192.168.100.25  TERMINATED. The Telnet/SSH session may still be co nnected.
Please kindly advise to solve this issue.
Thank you very much
6 Replies 6
mohabdel
Hi Max,
I see here you try to connect to SNMP program and this program use SSH.  I like to see your config file and I will try it with my own switch.  Also about Spicework, it is free program?
Moh
I will send switch configuration to your email.
please kindly provide your email address.
Yes, Spicework is a free program.
Spicework download link below
http://www.spiceworks.com/download/
Thank you very much.
Hi Max,
Could you do show run and copy SSH and SNMP  sections and port them here?
Moh
config-file-header
bkk-sw-25
v1.3.7.18 / R750_NIK_1_35_647_358
CLI v1.0
set system mode switch
ip ssh server
ip ssh password-auth
ip ssh pubkey-auth auto-login
crypto key pubkey-chain ssh
user-key admin rsa
key-string row AAAAB3NzaC1yc2EAAAADAQABAAAAgQDFMQiPsbOX
key-string row MMNocuKtdU2H/YOJvyZrDHrOennUGSGdffOCHBMg
key-string row v22OPzzO5fci3JTTv/Gck5Eo6HxadTjEQPgdqoxH
key-string row qoKZeLkASgVQ+ww4/uFHOYowX7xCN4kf
key-string row fxHCYiMCiHY23IVx6TYl8Yf9vWTf0q6N0WTd9/8j
key-string row 5h/U0yN6FQ==
exit
exit
snmp-server server
snmp-server engineID local 8000000903b8621fd588eb
snmp-server location "IT ROOM"
snmp-server community ciscosg300 ro view Default
snmp-server host 10.2.101.13 version 3 auth administrator udp-port 161
snmp-server group spicework v3 auth notify Default read Default write Default
encrypted snmp-server user administrator spicework v3 auth md5 jblmaMDCgbwhZ7DbT6DjE40YbGf6uBm1N12M7Xb6TZ0=
ip http timeout-policy 1800 http-only
no ip http secure-server
clock timezone ICT 7
clock source sntp
sntp unicast client enable
sntp unicast client poll
sntp server 10.2.101.1
interface vlan 1
 no ipv6 address autoconfig
 no ipv6 enable
 no ipv6 dhcp client stateless
interface vlan 5
 name VLAN_GUEST
interface vlan 10
 name VLAN_LAN
interface vlan 20
 name VLAN_MEDIA
interface vlan 30
 name VLAN_WIFI_PUBLIC
interface vlan 40
 name VLAN_ISP1
interface vlan 50
 name VLAN_ISP2
interface vlan 60
 name VLAN_TEST1
interface vlan 70
 name VLAN_TEST2
interface vlan 100
 name VLAN_MGMT
 ip address 192.168.100.25 255.255.255.192
interface gigabitethernet1
 storm-control broadcast enable
 storm-control broadcast level kbps 3500
 storm-control include-multicast unknown-unicast
 port security mode max-addresses
 port security discard
 spanning-tree bpduguard enable
 switchport mode access
 switchport access vlan 30
 lldp med enable
interface gigabitethernet2
 lldp med enable
interface gigabitethernet3
 switchport access vlan 10
 lldp med enable
interface gigabitethernet4
 lldp med enable
interface gigabitethernet5
 lldp med enable
interface gigabitethernet6
 lldp med enable
interface gigabitethernet7
 lldp med enable
interface gigabitethernet8
 lldp med enable
interface gigabitethernet9
 lldp med enable
interface gigabitethernet10
 lldp med enable
interface gigabitethernet11
 lldp med enable
interface gigabitethernet12
 lldp med enable
interface gigabitethernet13
 lldp med enable
interface gigabitethernet14
 lldp med enable
interface gigabitethernet15
 lldp med enable
interface gigabitethernet16
 lldp med enable
interface gigabitethernet17
 lldp med enable
interface gigabitethernet18
 lldp med enable
interface gigabitethernet19
 switchport access vlan 60
 lldp med enable
interface gigabitethernet20
 lldp med enable
interface gigabitethernet21
 lldp med enable
interface gigabitethernet22
 lldp med enable
interface gigabitethernet23
 switchport access vlan 40
 lldp med enable
interface gigabitethernet24
 lldp med enable
interface gigabitethernet25
 switchport access vlan 50
 lldp med enable
interface gigabitethernet26
 lldp med enable
interface gigabitethernet27
 storm-control broadcast level kbps 50000
 switchport trunk allowed vlan add 5,10,20,30,40,50,60,70,100
 lldp med enable
interface gigabitethernet28
 lldp med enable
exit
ip default-gateway 192.168.100.1
encrypted ip ssh-client key rsa key-pair
Remko de Koning
Hi, did you ever got this working? Looking for the same thing.
Also tried alternatives via Putty and input files to automate backups of these devices.
So far without luck.
Remko
Hi Remko,
I guess Jody answered your question.
https://supportforums.cisco.com/discussion/12375366/login-ssh-without-user-name-and-password
Automatic login was added only with 1.2.9 release.
Aleksandra
