Cisco SG350-28MP Fan
joy.yeo
Anyone know what kind of detection does SG350-28MP fan use? Rotation lock or frequency?
if changing the delta fan, i should choose ending with R00 or F00?
riteshsh
My name is Ritesh Sharma from Cisco TAC.
I would recommend not change the any hardware of the device. If the fan of the switch stops working you can open a case with us, if there is an hardware fault is detected, we will go ahead and replace the device.
Please go through the link below in order to open a case with us:
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Please mark this as helpful if it resolves your query.
Ritesh Sharma
Cisco TAC.
riteshsh
Ritesh Sharma
Cisco TAC.
