Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2810 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4353 Views
  • 1 replies
  • 16 Helpful votes
I have procured a new Cisco 3850 switch with IOS as shown below and I need to enable flexlink but that option is not available in this switch. Please advise.   Cisco IOS Software [Denali], Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Versio...
avilt by Level 3
  • 1919 Views
  • 3 replies
Hi community, I have network of 4 x SG500X. One 48-port modell is the middle of the star-topology, the other 3 switches are connected via a 10GB/s connection (fiber) to the center switch. No stacking.One of the 3 "satelite" switches is showing nearly...
MWI by Level 1
  • 657 Views
  • 1 replies
Good day!I have 7 Switches :  5 Swtiches SG-550X-48P-K9 V03                               1 Swtich SG-550X-24MPP-K9 V03                               1 Switch SG-550X-48MP-K9 V03 They have the same Firmware Version : 2.4.0.94 Now my question is.... T...
Hi, Cisco Community I've just Implement Core Switch as Stack type Ring with Small Business Switch. It's on production already.I've configured by fix unit 1 and unit 2,3 set autoUnit Id After Reboot ConfigurationUnit Id Stack Links-------- ------- ---...
I have a MGBLH1 SFP module. I inserted in CISCO 2960 and 3850 but it’s showing Bad CRC error and port goes in error disable state. when I inserted in Cisco SG350 model switch, there is no error detected but link is not getting detect. I can not under...
Hi guys, new here, signed up as can't figure this one out. I suspect a firmware bug for this switch. I've identified that our 2 SG200-50Ps are failing to forward frames between trunk port ingress (from router) and host port egress. VID10T on trunk li...
JD91415 by Level 1
  • 685 Views
  • 1 replies
Greetings all, I am hoping that a kind soul can help me with an older switch, the SRW2024P.The firmware download links are non-functional here: https://software.cisco.com/download/home/282414075/type/282463183/release/1.2.9 I am hoping to find the fi...
M_P by Level 1
  • 4740 Views
  • 2 replies
  • 5 Helpful votes
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
