10-02-2024 10:08 AM
I have a Cisco SG350-28 (SG350) running firmware 2.5.9.54, connected to a Firewalla Gold. The Firewalla is connected to my ISP cable modem. There are no other networking devices involved.
Having never administered VLANs, I am well out of my depth!
I have one VLAN that is working correctly. I have managed to create a second one that cannot access the Internet. Have I misconfigured my SG350, or my Firewalla, or both?
The working VLAN is VLAN 9:
interface vlan 9
name Management
ip address 192.168.168.2 255.255.255.0
ip dhcp relay enableThe default gateway on the SG350 is:
ip default-gateway 192.168.168.1Everything in the 192.168.168.0/24 network can ping the switch at 192.168.168.2 and the default gateway at 192.168.168.1 (the Firewalla) and access the Internet. Go, me!
The devices in VLAN 9 are connected to switch interfaces configured as below:
interface GigabitEthernet23
switchport access vlan 9
switchport general pvid 9
switchport trunk native vlan 9 There is one trunk interface, directly connected to the Firewalla:
interface GigabitEthernet1
switchport mode trunk
switchport trunk allowed vlan 9-10The Firewalla receives 10.0.0.3 from the ISP via DHCP, and has a static IP of 192.168.168.1.
The broken VLAN is VLAN 10:
interface vlan 10
name Engineering
ip address 10.10.0.1 255.255.255.0
ip dhcp relay enableI have configured the Firewalla with VLAN 10, static IP of 10.10.0.200.
My test machine is connected to:
interface GigabitEthernet14
switchport access vlan 10
switchport general pvid 10 The test machine has IP 10.10.0.5, and it can ping:
The test machine cannot reach the Internet:
ping -c 3 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
--- 8.8.8.8 ping statistics ---
3 packets transmitted, 0 received, 100% packet loss, time 2034msRouting information on the SG350:
cisco-sg350#sh ip ro
Maximum Parallel Paths: 1 (1 after reset)
IP Forwarding: enabled
Codes: > - best, C - connected, S - static
S 0.0.0.0/0 [1/4] via 192.168.168.1, 97:53:49, vlan 9
C 10.10.0.0/24 is directly connected, vlan 10
C 192.168.168.0/24 is directly connected, vlan 9 And routing on the Firewalla:
pi@firewalla:~ (firewalla-gold) $ ip ro
default via 10.0.0.1 dev eth0 metric 1
10.0.0.0/25 dev eth0 proto kernel scope link src 10.0.0.3
10.10.0.0/24 dev br1 proto kernel scope link src 10.10.0.200
64.59.128.121 via 10.0.0.1 dev eth0 metric 1
64.59.135.145 via 10.0.0.1 dev eth0 metric 1
192.168.168.0/24 dev br0 proto kernel scope link src 192.168.168.1 Have I configured the SG350 correctly?
Solved! Go to Solution.
10-05-2024 06:18 AM
I have found and fixed my mistake: I had asymmetric routing. My configuration on the SG350 and the FWG were correct.
I had the test machine incorrectly configured with the SVI as its gateway. Instead, the gateway needed to be the IP of the FWG. Once I corrected that, everything worked.
Go me!
10-02-2024 10:25 AM
I believe the problem is related to NAT. The firewall is natting the network 192.168.168.0 but not the network 10.10.0.0. that´s why the traffic is failing.
The SG350 seems to be configured correctly. What you coudl do differently would be to create a point-to-point connection between the SB the firewall, instead the trunk. You can use the 192.168.168.0 network for it.
Then, you can create a static route on SG sending all the traffic to the firewall via this layer3 connection. But, the way you did should work as long as the firewall perform the NAT for both network.
10-03-2024 06:50 PM
I contacted the helpful team at Firewalla, and they believe I've configured the Firewalla Gold (FWG) correctly.
I still believe I have misconfigured either the SG350 or the FWG. Or both.
A traceroute to 1.1.1.1 from 192.168.168.0/24, VLAN 9 works.
A traceroute to 1.1.1.1 from my test machine at 10.10.0.5 only goes as far as the Switch Virtual Interface (SVI) 10.10.0.1. From there ... nothing. Shouldn't the next hop be to 192.168.168.1, the default route?
I think this suggests something needs to change in the SG350.
10-05-2024 06:18 AM
Go me!
