Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board from June 18th - July 18th. These dates are subject to change pending progress. This in...
CoreyP319 by Cisco Employee
  • 559 Views
  • 0 replies
  • 1 Helpful votes
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5534 Views
  • 1 replies
  • 16 Helpful votes
I have two VLANs, 10 and 40, with external ISC-DHCP servers in VLAN 10. I am successfully relaying DHCP across VLANs: a PC in VLAN 40 can request a DHCP lease, receive the offer, and accept the IP. My working configuration includes:ip dhcp relay addr...
In response to the bug described at: https://bst.cisco.com/quickview/bug/CSCwi16752The issue also occurs with the latest version 3.4.0.17. Switch model CBS350-12XS. The bug severity is set to Moderate, however, the CLI and GUI freeze for 10 minutes. ...
mis by Level 1
  • 375 Views
  • 0 replies
25-Jun-2015 08:44:45 %BRG_IGMP_QRR-W-DUPLICATE_IP: Duplicate IGMP Querier IP address 192.168.142.1 detected on VLAN 1. Remote MAC address is 34:a8:4e:0d:34:55. I am seeing this regularly on this SG300-28P switch.  These IP and MAC addresses belongs t...
How can I do my cisco 250 unmanaged?(Cisco Business 250 Series 250-48T-4G Switch 4)I have an issue to test.a software program, can't go trough the switch out, it blocks? If bypassing the switch direct to the router it works.
Tom Holck by Level 1
  • 328 Views
  • 2 replies
Hi community,I'm a bit confused...I recently got a CBS350-24P-4X 1U managed switch, which comes with a wall-mount/rack-mount (I guess?) kit and I'm wondering, how I could manage to install this kit onto the device in order to align the rackmount-ears...
Hi,   have here a nativ 2*SG550XG-8F8T stack. Today I received this messages.   It looks like only unit 2 was rebooting, but the unit 1 master did not respond to pings, at least 1-2 minutes at this time. Therefore our HA disk appliance (iSCSI & NFS) ...
I have a Cisco SG350-28 (SG350) running firmware 2.5.9.54, connected to a Firewalla Gold. The Firewalla is connected to my ISP cable modem. There are no other networking devices involved.Having never administered VLANs, I am well out of my depth!I ha...
Hi team  i want to check warranty of my Cisco device  so we can extend warranty with you and i have check with your tool warranty finder. This tool not provide correct information. So, please provide right tool for me so we can check ;warranty status...
Hello,I am using Cisco SG300-28 Switch. Few days ago, the Network connectivity was down on one of the trunk port. I found an abnormality on that port in running configuration of the switch.In startup configuration, the port configuration was as under...
malay by Level 1
  • 2852 Views
  • 3 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
