Cisco SG350XG-24F - SNMP Monitor VLAN Traffic
I have a couple of Cisco SG350XG-24F which are in layer 3 mode with a number of VLANs setup.  When using SNMPv2 to monitor I can add SNMP traffic sensors in PRTG for each of the VLAN IDs though these only show zero for traffic counters.  Adding the same traffic sensor for an interface reports traffic levels correctly.
Is there something I am missing to allow the VLAN interface to be reported on?
SNMP Setup:
snmp-server server
snmp-server engineID local 80000009033c57312c0fd6
snmp-server view All system included
snmp-server view All interfaces included
snmp-server view All ip included
snmp-server view All icmp included
snmp-server view All tcp included
snmp-server view All udp included
snmp-server view All transmission included
snmp-server view All snmp included
snmp-server view All rmon included
snmp-server view All ifMIB included
snmp-server community snmpuser ro 1.2.3.4 view All
marce1000
 - Can you walk the iflist to verify the correct vlan-ids and or do a few (manual) snmp gets on the vlan-traffic oid's on them to see if traffic-stats are generated.
 M.
