I have problem with simple VLAN:
I change switch to layer 3 system mode.
To port 1 I have connected router. I create 2 vlans:
VLAN settings: vlan id 2 and vlan id 4
I go to Port VLAN Membership and I join vlan to GE2 2T, GE3 2T, GE4 4T, GE5 4T (I left 1UP in every GE).
Next I have done almost all possibly configuration:
I made port 2,3,4,5 in access mode\trunk\general. I change them to tagged/untagged...
I want to do:
GE1 router/internet is visible for (port): 2,3,4,5.
Port 2 and 3 are visible for themselfs and not visible for 4 and 5.
Port 4 and 5 are visible for themselfs and not visible for 2 and 3.
I get IP from router via DHCP.
I configure cisco swith via web.
Can you help me with rest configuration?
Other questions:
1. I read that it is better to use VLAN based on ports than VLAN based on MAC. Why?
2. Should I configure my router to use this VLAN (besides DHCP)? (I use Microtik)
3. If I want to add server on port 20. (Access from every port (like router)) Do I have to configure port 20 the same as port 1?
Karol
