Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3599 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5281 Views
  • 1 replies
  • 16 Helpful votes
Resolved! Radius on SF200-24
Just got a SF200-24 (SLM224GT) in to configure for a small office. According to the product manual and the web gui it should support RADIUS authentication. The switch is running the latest firmware 1.3.5.58. Full logging including debug is enabled.Ra...
thni by Level 1
  • 1962 Views
  • 2 replies
hi,What is the best way to connect switch together (with 2960 switch)..cross or stright cable...up/down or normal port ?WAN ----Router 1 --- -SW1 ---- SW2                                  |                                  |                          ...
t80243280 by Level 1
  • 815 Views
  • 1 replies
Hello,I want to setup VLAN to separate attached devices (will use a VLAN capabel WLAN accesspoint).I am looking at the Cisco Small business products.Like this: SG200-08PThis is my goal:3 VLAN's: Internal, External, GuestDevices connected to Internal ...
samboman1 by Level 1
  • 979 Views
  • 3 replies
Hi all,I have recently received a SG200-26P poe switch to potentially upgrade the office switch.So on first boot - it went through its post, got a solid green light.I then connected my PC to the first port to try and configure it via the web interfac...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
