Cisco small bsuiness Network issues
nicthyd
I have small business network with following equipment
Comcast Providers Internet Router
SA520W Security Appliance
SG300-20-20Port Small Business Switch
From Comcast Router Internetworks fine
after connect SA520W Router I am unable to resolve the host name very quickly its too taking long to resolve  host name to IP address while resolving  dns is getting failed . I thought  there might some issues with Comcast , Comcast tested and no issues their router set to bridge mode .
After that I come to conclusion that SA520w has some firmware issue  , I updated the new version of firmware for sa520w
After that connected switch sg300 series after connecting the switch I have similar issue again
Do I need updated the firmware for the switch as well ,can some one provide firmware Link
Or any thoughts on present issue
R
cchamorr
Level 5
Level 5
Im sorry you are having issues with the devices. I really have no idea what could be the problem. Maybe you can try using the DNS servers from google, 8.8.8.8, 4.2.2.1, 4.2.2.2?
Also, here is a link to the firmware upgrade for the SG300-20.
https://software.cisco.com/download/release.html?mdfid=283019616&flowid=18904&softwareid=282463181&release=1.4.0.88&relind=AVAILABLE&rellifecycle=&reltype=latest
When upgrading the firmware, please keep in mind you should step up the upgrade and please don't go straight to the last one as you may break the device.
Starting on firmware 1.3.5.8 you will also need to upgrade the boot code when upgrading the firmware.
Here is a document that explains the process.
http://sbkb.cisco.com/CiscoSB/ukp.aspx?vw=1&docid=08ef98be59904ccc9c4d69a657f5550f_Firmware_Upgrade_via_TFTP_on_200_Series_Switches.xml&pid=2&respid=0&snid=4&dispid=0&cpage=search
Please let us know if you have any more questions
