Cisco Small Business Managed Switches SRW224G4P
THE PROBLEM=
Image Loader 1.0.1
Loading Diagnostic Image File : SRW224G4P_SRW248G4P_boot.bix
Diagnostic 1.0.1
(!)Loader Binary checksum error
SOLUTION METHOD
By pressing CTRL+U
Image Loader 1.0.1
File Name                         S/Up Type Size       Create Time
$logfile_1                          0    3         64  1193046:28:15
Factory_Default_Config.cfg          0    5        354  24:01:02
SRW224G4P_SRW248G4P_boot.bix        1    1    1377600  00:01:03
SRW224G4P_SRW248G4P_image.bix       1    2    3517532  00:03:42
certificate                         0    8      18040  24:00:55
startup-config                      1    5       5596  25:40:57
startup1.cfg                        0    5       5537  24:01:14
Free Space : 2097152
[X]modem Download  [D]elete File  [S]et Startup File
[Q]uit
Select>
I NEED STOCK COPY FROM ALL OF THE ABOVE FILES ALSO COMPATIBLE WITH BOOT LOADER 1.0.1
PLEASE BE KIND AND SEND THE NECESSARY FILES.
WITH REGARD.
MUHAMMED AL-FTESI FROM LIBYA
Mark Elsen
 - This thread may contain hints ; mind you if xmodem recovery is not possible, the device may need to be rma-ed :
          https://community.cisco.com/t5/small-business-switches/srw248g4p-loader-binary-checksum-error-lt-err-gt-runtime-loading/td-p/2201092
 M.
THANKS BUT I NEED THE RIGHT FIRMWARE FILES TO TRY.
I HAD TRIED UPLOADING VIA XMODEM AND I GOT File system update fail, BUT BECAUSE IT'S THE WRONG VER.
SO IF YOU HAVE THE OFFICIAL FIRMWARE OR THE IMAGE OR BOOT FILE PLEASE UPLOAD THEM OR SEND THEM BY EMAIL.
THANKS FOR THE HELP.
 - Below you will find a (sample) download page :
        https://drivers.softpedia.com/get/Router-Switch-Access-Point/Linksys/Linksys-SRW224G4-Switch-Firmware-1230.shtml
 M.
Hello Muhammed,
Please find below the link with the Sx300 (SRW224G4P) available firmware images.
https://software.cisco.com/download/home/283019681/type/282463181/release/1.4.11.5
Martin
