Cisco SMB 110-16pp Amber Flashing light
tlavens01
hi there...I have a Cisco 110-16-PP SMB switch.  I have a cable connecting my Xfinity modem/router to a non-POE port on this switch.  The left LED light on this port is flashing Amber, and the right LED light is solid green. This suggests a network loop of some kind.  However, as a test, I unplugged everything else from the switch except the connection from the modem/router to the switch, and the flashing amber LED remains.  If there is nothing else connected to the switch, how can I have a network loop? Or is this a faulty switch?
thank you,
Trevor
7 Replies 7
marce1000
      - FYI : https://community.cisco.com/t5/switches-small-business/sg110-leds/m-p/3301777#M19339
        Check logs on the device too , and or when a connection attempt with a foreign device is attempted
 M.
Thanks. I’ve read this thread. It doesn’t answer my question. And given that this is an unmanaged switch, I don’t believe there are any logs.
  - Then that may be your 'fatal problem'  ; being an unmanaged switch which should be at all cost
     avoided in modern networks (the use of them)
  .  Because there is no configuration handling possible if a connected device
     has special requirements concerning spanning tree , VTP , ...
   M.
This didn’t answer the question about the switch.
  - The logic of the device is probably too simple (too) , to recover from that condition. Try a full power cycle ,
 M.
I Cycled the power. Same behavior. Note: I’m looking for an answer as to why a single connection (from a modem) to a switch would yield a flashing Amber, suggesting a network loop, when there isn’t a single other device connected to the switch. Suggesting I throw away the switch isn’t a solution.
  - If the light remains flashing Amber with no connections at all and after power up then the device could have a hardware problem.
    You may also try and look at the logs on the modem when the connection to the switch is made (if available)
                 >...Suggesting I throw away the switch isn’t a solution.
    - Note that the forums are populated by customers based on best effort. For   for official Cisco support checkout :
        https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
  M.
