Cisco Switch 3650 SYST light flashing green
Cisco Switch 3650 SYST light flashing green and all the ports are not working, how do I fix this.
Jitendra Kumar
Connect Console with the Switch and share what is the output.
If console connects surly image will be corrupted and will on ROMON so you have to re-image it.
if nothing happens in the console Raise an RMA for that
Jitendra
balaji.bandi
as other suggestion, connect console and check, if nothing, then Raise a TAC case for RMA.
BB
