cisco switch issue
Dear All,
Please help me i have cisco switch catalyst C2960S POE when i connect POE camera its not able to connect.
when i login to the switch its giving me this message:
*Mar 1 15:49:33.060: %ILPOWER-7-DETECT: Interface Gi1/0/47: Power Device detected: IEEE PD
SECURITY-GATE-1#
*Mar 1 15:49:34.062: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/47: PD removedSECURITY-GATE-1#
*Mar 1 15:49:35.073: %ILPOWER-7-DETECT: Interface Gi1/0/47: Power Device detected: IEEE PD
SECURITY-GATE-1#
*Mar 1 15:49:36.106: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/47: PD removedSECURITY-GATE-1#
*Mar 1 15:49:38.120: %ILPOWER-7-DETECT: Interface Gi1/0/47: Power Device detected: IEEE PD
SECURITY-GATE-1#
*Mar 1 15:49:39.116: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/47: PD removedSECURITY-GATE-1#
*Mar 1 15:49:41.155: %ILPOWER-7-DETECT: Interface Gi1/0/47: Power Device detected: IEEE PD
SECURITY-GATE-1#
*Mar 1 15:49:42.162: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/47: PD removedSECURITY-GATE-1#
Port configuration is:
interface GigabitEthernet1/0/47
switchport access vlan 30
spanning-tree portfast
If i connect the camera direct with the laptop providing power to the camera by adapter then the camera is working fine
Please advise
5 Replies 5
Mark Malone
can you post the show power inline , when camera is connected
also what type of poe is camera using and what watts
Dear Mark,
Camera is 1000 watts
SECURITY-GATE-1#sh power inline
Module Available Used Remaining
(Watts) (Watts) (Watts)
1 370.0 34.3 335.7
Interface Admin Oper Power Device Class Max
(Watts)
Gi1/0/1 auto on 3.5 IP Phone 6911 1 30.0
Gi1/0/2 auto off 0.0 n/a n/a 30.0
Gi1/0/3 auto off 0.0 n/a n/a 30.0
Gi1/0/4 auto off 0.0 n/a n/a 30.0
Gi1/0/5 auto off 0.0 n/a n/a 30.0
Gi1/0/6 auto off 0.0 n/a n/a 30.0
Gi1/0/7 auto off 0.0 n/a n/a 30.0
Gi1/0/8 auto off 0.0 n/a n/a 30.0
Gi1/0/9 auto off 0.0 n/a n/a 30.0
Gi1/0/10 auto off 0.0 n/a n/a 30.0
Gi1/0/11 auto off 0.0 n/a n/a 30.0
Gi1/0/12 auto off 0.0 n/a n/a 30.0
Gi1/0/13 auto off 0.0 n/a n/a 30.0
Gi1/0/14 auto off 0.0 n/a n/a 30.0
Gi1/0/15 auto off 0.0 n/a n/a 30.0
Gi1/0/16 auto off 0.0 n/a n/a 30.0
Gi1/0/17 auto off 0.0 n/a n/a 30.0
Gi1/0/18 auto off 0.0 n/a n/a 30.0
Gi1/0/19 auto off 0.0 n/a n/a 30.0
Gi1/0/20 auto off 0.0 n/a n/a 30.0
Gi1/0/21 auto off 0.0 n/a n/a 30.0
Gi1/0/22 auto off 0.0 n/a n/a 30.0
Gi1/0/23 auto off 0.0 n/a n/a 30.0
Gi1/0/24 auto off 0.0 n/a n/a 30.0
Gi1/0/25 auto off 0.0 n/a n/a 30.0
Gi1/0/26 auto off 0.0 n/a n/a 30.0
Gi1/0/27 auto off 0.0 n/a n/a 30.0
Gi1/0/28 auto off 0.0 n/a n/a 30.0
Gi1/0/29 auto off 0.0 n/a n/a 30.0
Gi1/0/30 auto off 0.0 n/a n/a 30.0
Gi1/0/31 auto off 0.0 n/a n/a 30.0
Gi1/0/32 auto off 0.0 n/a n/a 30.0
Gi1/0/33 auto off 0.0 n/a n/a 30.0
Gi1/0/34 auto off 0.0 n/a n/a 30.0
Gi1/0/35 auto off 0.0 n/a n/a 30.0
(Watts)
Gi1/0/36 auto off 0.0 n/a n/a 30.0
Gi1/0/37 auto off 0.0 n/a n/a 30.0
Gi1/0/38 auto off 0.0 n/a n/a 30.0
Gi1/0/39 auto off 0.0 n/a n/a 30.0
Gi1/0/40 auto off 0.0 n/a n/a 30.0
Gi1/0/41 auto off 0.0 n/a n/a 30.0
Gi1/0/42 auto off 0.0 n/a n/a 30.0
Gi1/0/43 auto off 0.0 n/a n/a 30.0
Gi1/0/44 auto off 0.0 n/a n/a 30.0
Gi1/0/45 auto off 0.0 n/a n/a 30.0
Gi1/0/46 auto off 0.0 n/a n/a 30.0
Gi1/0/47 auto faulty 0.0 n/a n/a 30.0
Gi1/0/48 auto on 15.4 Ieee PD 3 30.0
Thanks for responding
Hi so poe is working fine looking at that output you have 330 watts remaining but your trying to power a 1000 watt camera on a port that has a max of 30 watts per use  , are you sure its using that much ? a phone uses 15.4 , max is 30 watts per port
is camera plugged into g1/0/47
Camera voltage is 12v  2.0A it means 24 watts sorry for wrong information in previous email.
and yes the camera is plugged into g1/0/47
ah 24 seems about right :)  does it say what poe it uses , 2960s support 802.3af poe
you can try set the port as well to static instead of auto as an option
couple of options in this doc below for 2960s  but the most important thing is probably confirm what type of poe it uses and if the Cisco switch matches it
let me know if setting it to static works and if you find the poe type of the device
Try this command as well if the above fails it was a bug fix ----power inline 2x-port
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_44_se/configuration/note/ol14988.html
This is a POE Tshoot doc as well maybe something in it
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/troubleshooting/g_power_over_ethernet.html
