cisco switch sg-300-10mp
oran19711
I am able to log in via web gui but not all text is visible .
did reset several times .
any ideas ?
8 Replies 8
ghostinthenet
Level 7
Level 7
What browser are you using? I've seen these symptoms when newer versions of Internet Explorer are used. Once you put the site into compatibility mode, everything usually clears up. Have you tried multiple browsers?
internet explorer in windows 7.
Try adding the address of the switch to the Compatibility View Settings and refreshing. That should clear it up .
thanks, I`ll try that.
Did that do the trick?
yes it did.
thanks.
I'm glad to hear it.
When you have a moment, please mark one of the replies as correct so that this question no longer appears in the "unanswered questions" list.
Mehdi Boukraa
Hi Oran,
Please check this link may help you on this issue :
https://supportforums.cisco.com/discussion/12358601/sg200-50p-web-interface-problems
Please rate this post or marked as answer to help other Cisco customer
Mehdi
