11-27-2014 11:12 AM
I am able to log in via web gui but not all text is visible .
did reset several times .
any ideas ?
11-27-2014 02:23 PM
What browser are you using? I've seen these symptoms when newer versions of Internet Explorer are used. Once you put the site into compatibility mode, everything usually clears up. Have you tried multiple browsers?
11-27-2014 02:38 PM
internet explorer in windows 7.
11-27-2014 02:40 PM
Try adding the address of the switch to the Compatibility View Settings and refreshing. That should clear it up .
11-27-2014 03:55 PM
thanks, I`ll try that.
11-27-2014 09:46 PM
Did that do the trick?
11-29-2014 06:52 AM
yes it did.
thanks.
11-30-2014 07:53 AM
I'm glad to hear it.
When you have a moment, please mark one of the replies as correct so that this question no longer appears in the "unanswered questions" list.
11-28-2014 12:16 AM
Hi Oran,
Please check this link may help you on this issue :
https://supportforums.cisco.com/discussion/12358601/sg200-50p-web-interface-problems
Please rate this post or marked as answer to help other Cisco customer
Mehdi
