06-16-2015 01:22 AM
I have a Cisco SG300 but am unable to log in to the web interface. I was able to a few months ago.
This time around I did try a few different passwords before I remembered it was still the default password.
Is there a lockout time period if you enter the wrong credentials a certain number of times?
Thanks in advance
Solved! Go to Solution.
06-16-2015 02:38 AM
Hi there is a password expiry under security-password section default 180 days timeout not sure about lockout dont see anything regarding that , you can do a password recovery though through cli or factory reset and reload your config
https://supportforums.cisco.com/discussion/12215636/sg300-how-recovery-password-cli
06-16-2015 02:41 AM
Take a look at posting below.
hope this helps
please rate helpful posts
thanks
06-16-2015 02:38 AM
06-18-2015 08:59 AM
Thanks mark malone.
Managed to get it all sorted now.
Much appreciated!
06-16-2015 02:41 AM
hope this helps
thanks
06-18-2015 09:00 AM
Thanks for your help, it is much appreciated.
Managed to get this resolved now.
Cheers
06-18-2015 09:06 AM
Your welcome.
glad you got it resolved.
