Ciscp 2960G Factory reset
I have a Cisco Catalyst 2960G-24TC-L Switch with i did a reset of by holding down the mode button until it reboored itself
After it rebooted i cant access the router anymore, i get "access denied" from both the HTTP interface aswell as when im trying to SSH, why is this ?
How i reset it > https://www.youtube.com/watch?v=UK79B04J-TQ
7 Replies 7
Mark Malone
is the config still on it ? when you console in do you get your username or just cisco default
Maybe first time im trying to reset it and i belive of what i have read i cant reset it with the button while it's there?
This is the first time im trying to use the console as im learning about this stuff so what i have done is that i put the switch next to my PC now, i put a network cable from the Console Port on the Switch to my network port on my PC. I opened Pytty and tried to use serial to get into the switch but when i have choosen Serial on COM1 i only get a black putty windows. Hitting entern work make anything appear, why ?
You need a Cisco serial cable connect it to the console port on the switch and connect that to your pc
Check you device manager in your pc com ports see which 1 is active when the cable is connected
check this
https://www.youtube.com/watch?v=7sM4f1_QloQ
Ah i set... Is the Serial cable RJ45 / Pin only(as in the image) so that i will need an adapter or are there rj45 / rj45 serial cables?
http://www.routerswholesale.com/images/72-3382-01-large.jpg
you can connect it direct to desktop pc but for laptop you will need an adapter usually
Hi again!
I managed to get into the switch trough the console port.
i tried "flash_init" or "del flash:config.text" but i get "unknown command or computer name" domain server 255.255.255.255
How do i reset the switch to factory default ?
you can either wipe the contents of flash using delete flash:(file name) , make sure to leave the image so switch has something to boot up or follow the guide below while your consoled in
http://notthenetwork.me/blog/2013/05/28/reset-a-cisco-2960-switch-to-factory-default-settings/
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
