CLI SG200-50
Dado
Hi guys.
I am newer in the community.
I have 5 sg200-50 switches . By default only WEB GUI is enable to management it.
I have found a trick to enable telnet :
- download the configuration.txt
- Edit it with notepad+
- After the line "username cisco password encrypted d3f1e79cbc683d1f0c4df3c89b31cf71b5494942 privilege 15 " you have to put " ip telnet server"
- Save the file
- Upload the new file .txt on the switch
- copy running* to startup*
Now you are able to connect to the switch >>>>>   telnet <ip address> 6500
But , someone of you known how to enable ssh?
Bye bye
6 Replies 6
balaji.bandi
Look at the command level managment check is that supported ?
BB
Thank you for help.
But when I write copy nvram:sshkey-rsa   it asnwers   "unrecognized command" ..
Have you idea why?
 the command is not full right ? what are you copyig ? from where to where ? - check the command sysntax.
BB
Where Can I download ssh-rsa2 key from ?
copy url nvram:sshkey-dsa
this process for :
SSH Access
The following commands configure user access to the management interface
through SSH.
BB
Estimado será que me pueda ayudar con un switch cisco sg200-50p, intente subirlo de versión, primeramente tenia el fireware  1.3.2.2 y lo subí de golpe a la ultima versión 1.4.11.5 despues le di guarda y reiniciar, ahora el sw se reinicia y no arranca.
