Command prompt to deploy one command in a script
kevinmelka1
Hello everybody :D,
I want to deploy a script to deactivate "HTTP" for 30 switches with the following command : "no ip http server".
As i have 30 switches, i don't want to make this command one switch by one.
To do it, i want to deploy this command in a script thanks to Nedi (a open-source tool to manage network equipments)
The problem is i don't know the command prompt of SG300 switches to make this list of commands :
conf t
no ip http server
exit
wr mem
Y
Anyone knows what is the command prompt to use ?
Thank you in advance :).
greenkev
I see.  Did you try Nedi forums then?  How about this? http://forum.nedi.ch/index.php?topic=1605.0
-- please remember to rate and mark answered helpful posts --
8 Replies 8
Brandon Svec
Level 7
Level 7
I would try:
configure
no ip http server
exit
copy running-configuration startup-configuration
y
Brandon Svec,
Thanks for your help but unfortunately, your command doesnt't mach :s.
Other ideas ?
Can you provide more details about where you are having trouble then?  Do you have some log showing failure/errors?
Those commands work on my SG300.  The commands you posted orginally should also work, by the way.  Did you try entering them manually on a switch to check before doing your script?
You can reference the CLI guide for exact command definitions:  http://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/CLI_Nikola300_1_3_7.pdf
Of course, tab and ? will reveal the correct commands too.
If i make commands directly in the switch, i don't have problems.
In this case, I use Nedi, an open source tool to manage network equipments like Nagios...
When i make commands in Nedi by a script, there are nothing in logs (you can look the picture in attachment).
Thanks Brandon, i already posted the same topic in Nedi forums --> http://forum.nedi.ch/index.php?topic=1905.0
I'm waiting answers.
I have an other question about SG300 switch.
It's possible to drop the message "Overwrite file [startup-config].... (Y/N)[N] ? when we do "wr mem" :
I want that when i do a wr mem, the command yes launch automatically.
I could be wrong, but I don't think so.  If you are running a script it shouldn't matter though, right?  Did you manage to get your backup script working?  If not, you may consider using expect.  Here is an example I found: http://technologyordie.com/cisco-configuration-backup-script
