COMPARISON BETWEEN SX350X-24F AND CBS350-24XS
subratabiswas1
Would you kindly share detail comparison between  SX350X-24F AND CBS350-24XS?
Thanks a lot in advance.
Rgds.
Subrata
2 Accepted Solutions
Sujoy Paria
Even though the ready-made compare models options are available for the 350 series, 350X series and CBS350 series switches but it is not exactly available between the models you are looking for (SX350X-24F and CBS350-24XS).
You will get all the relevant information about those two switches on the respective data sheet.
Cisco 350X Series Stackable Managed Switches Data Sheet:
https://www.cisco.com/c/en/us/products/collateral/switches/350x-series-stackable-managed-switches/datasheet-c78-735986.html
Cisco Business 350 Series Managed Switches Data Sheet:
https://www.cisco.com/c/en/us/products/collateral/switches/business-350-series-managed-switches/datasheet-c78-744156.html
Compare models links are as follows for your reference:
https://www.cisco.com/c/en/us/products/switches/350x-series-stackable-managed-switches/compare-model.html
https://www.cisco.com/c/en/us/products/switches/business-350-series-managed-switches/models-comparison.html
https://www.cisco.com/c/en/us/products/switches/350-series-managed-switches/models-comparison.html
@subratabiswas1
In addition to Sujoy, you can have a high-level overview of what the major differences are between the legacy 200/300/500/220/250/350 series and the new generation of Cisco CBS220/250/350 families switches following the link below.
https://www.cisco.com/c/en/us/products/collateral/switches/business-250-series-smart-switches/nb-06-bus-switch-trans-guide-cte-en.html?ccid=cc001531
In general, besides the newer hardware, the below features are amongst the major key differentiators:
- More SFP slots for higher uplink
- Higher PoE budget
- New modern web UI
- Simplified full stack management with the CIsco Business Dashboard
- New and elegant design with Oslo snow white metal case
9 Replies 9
Sujoy Paria
Thanks a lot Sujoy.
Thanks a lot Martin.
Rgds.
@subratabiswas1
- Higher PoE budget
- New modern web UI
I know this is an old post but I currently have to decide whether to buy an SX350X-24F or an CBS350-24XS and noticed a major difference in the datasheet: The SX-Series Switch has an mpps of 357,12 (enough to saturate all 24 Ports with 10Gbit), the CBS-Series Switch has an mpps of only 240. Do you know if this is this really correct, or maybe a mistake in the datasheet?
Florian
Hi Florian,
According to the official Cisco datasheet both these switches have the same capacity being 240 Mpps.
You may have confused the SX350X-24F with the SG350XG-24Tor the SG350XG-24F.
Here are the links to Cisco:
Michael
Hi Michael,
thanks for that, yes I am talking about the SX350X-24F, it costs as much as the CBS350X-24XS so I don't know why I would buy the successor with worse performance, if that is correct.
Best regards
Florian
Thank you Sujoy.
Rgds.
sbaeuro01
